SLK 230 Front End too Low - Mercedes Benz SLK Forum
  • 1 Post By Durkatlon
#1 Old 03-21-2011
Vehicle: 2001 SLK230
The front end on my 2001 SLK 230 seems way too low. The tires are almost hitting the inside of the wheel wells. I replaced the struts last fall with Bilsteins and that helped a little but now it seems way to low and looks really messed up. I am thinking of replacing the coil springs with BOGE.
Does that seem like the right thing to do to correct this? The car has standard suspension and hasn't been lowered. Can I replace those myself?
jmorse62 is offline
#2 Old 03-21-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Any pictures?
Durkatlon is offline
#3 Old 03-22-2011
Front End Pics
I took a few pictures of the front end but I dont know how to get them on here. I have a picture of the front straight on to show the height, a side picture of how the tire sits insode the wheel well, and a picture I took by putting the camera under the car and shooting up to show the spring. I can email them to you or post them here if I figure it out.
jmorse62 is offline
#4 Old 03-22-2011
Quoted: 6498 Post(s)
go advanced and then manage attachments and upload
#5 Old 03-22-2011
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Has the wheels and tires been changed or are they stock?
Gbarringer100 is offline
#6 Old 03-22-2011
Stock wheels and regular tire. I don't think there has been anything changed from the original suspension package.
jmorse62 is offline
#7 Old 03-22-2011
Quoted: 99 Post(s)
Okay stock wheels and tires, when I bought my 2001 someone had rotated the tires and the rear wheels and tires were one the front and there was a rub in a sharp turn until I got the wheels and tires in the correct places. I was just checking if this could havde happen to you.
#8 Old 03-22-2011
The tires are in the correct spot. I think the wheels are all the same.
jmorse62 is offline
#9 Old 03-22-2011
Quoted: 99 Post(s)
The front rims are 7.5 inches and the rear tims are 8.5 inches if the are 16 inch rims. They are marked on the back of a spoke on each rim. The offset is also different for the front and the rears.
#10 Old 03-22-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Here's the pics that Joseph took. He emailed them to me. The car doesn't look particularly low to me, but I might be wrong.
GaryMedia likes this.
The Following 2 Users Say Thank You to Durkatlon For This Useful Post:
#11 Old 03-23-2011
How about a side profile shot of the entire vehicle? Hard to judge from the photos so far.
etyu is online now
#12 Old 03-23-2011
I'm sure the front end is too low. I have compared it to other SLKs and the clearance between the tires ans the wheel wells is much less on my car. Those pictures don't really give a good description. I don't know how to upload any pictures here.
Lets just assume that the front end is too low. Could that be from worn springs, or could it be something else. I did replace the struts last year which helped for a while.
Thanks for the help.
jmorse62 is offline
#13 Old 06-25-2011
Is this the right rim for the front of a 2001 SLK 230?
Uploaded with ImageShack.us
I lloked around and found a pdf with all the parts for an SLK (pretty nice). It shows this rim number (A 170 401 02 02)to be from a 98-99, and that an 01 should have 208 401 09 02. Does anyone know if there is a difference in size between those two rims?
jmorse62 is offline
Tags
bilstein, boge, low, slk230, suspension
SLK 230 Inspection Checklist slk230_itch SLK R170 General Discussion 56 06-27-2019 11:24 AM
Jacking up front end sokoloff SLK R170 General Discussion 14 09-03-2009 03:39 PM
Red Mercedes SLK 230k convertible - low miles imaculate stuarm SLK Cars For Sale 0 07-30-2009 01:43 PM
SLK 230, break pads... HBK SLK R170 General Discussion 4 11-07-2008 04:44 PM
