Will these wheels fit ? - Mercedes Benz SLK Forum
#1 Old 12-29-2014
Vehicle: 2007 R171 200
Quoted: 9 Post(s)
just bought 2 new set of rims. Both 19" and 8.5J / 9.5J.
One set (BBS OEM) has these spec's:
F: 245/35 ET:32
R: 275/30 ET:32
The other set (original AMG style 5):
F: 235/35 ET:30
R: 255/30 ET:31
I have no idea if these will fit my 2007 R171 with sport suspension without rubbing the fenders or hitting the calipers.
Is there a list of possible tiresizes on 19" rims ?
Thanks.
Paul
Paulus de B. is offline
#2 Old 12-29-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Try this :
Mercedes-Benz Fitting Chart and Wheel Fitment Guide | Alloy Wheels Direct
curro101 is offline
#3 Old 12-30-2014
Quoted: 9 Post(s)
Thanks!
Is there anyone at SLKWorld who's fitted 245/275 tires on 19" ?
Are te wheelarches of an 55 AMG version wider than a regular 171 ?
I found this website to be very usefull.
http://www.1010tires.com/Tools/Tire-Size-Calculator
Turns out only the 245 front BBS wheel could be a problem....
Thanks again.
Paul
#4 Old 12-30-2014
Quoted: 536 Post(s)
Or try this one ET-Waarde Configurator » ET-Waarde Berekenen » Oponeo.nl
You will see that compared with the original MB recommendation of 7.5J 18 225 ET37 front you will need for the rim only on the inside 8 mm more space and outside 18 mm for the BBS. And then you have to add some 10 additional mm because you have now 245 tyres instead of 225. So that gives some 18 mm inside and 28 mm outside. All without spacers ofcourse.
Hmm... I think that will be quite a challenge..
As for the AMG's, I tried 235/8.5J with ET35 and they rubbed the suspension. But with ET30 they come a little more outward, and that could give you just enough play.
Sneaky Pete is offline
#5 Old 12-30-2014
Quoted: 9 Post(s)
Hi Pete,
in the hyperlink curro101 gave I see the following possible configuration:
19x8.5 30 225/35R19 19x9.5 35 255/30R19
This comes close to the data of my BBS rims. I'm no expert but we'll see. Next Monday I'll try all wheels on to see if they fit. I'll keep you posted.
Thanks,
Paul
#6 Old 12-30-2014
Quoted: 536 Post(s)
Effe in 't Nederlands onder elkaar Paul,
ben wel eens benieuwd of dat past.
Ik kreeg 235 ET35 met 8.5J niet passend zonder spacers.
Nou heb jij met die BBS wel weer een lagere ET-waarde dus komen ze wat meer naar buiten. 235 moet wel lukken denk ik maar 245? Laat maar eens weten, ben benieuwd.
Grtz, Piet
#7 Old 12-30-2014
Quoted: 9 Post(s)
Grtz, Piet
Hoi Piet,
hoeveel mm spacerdikte had je nodig ?
Gr.
Paul
#8 Old 12-30-2014
Quoted: 536 Post(s)
Ik heb ze nooit gemonteerd gehad Paul.
Is een heel verhaal maar uiteindelijk heb ik ze weer verkocht.
Maar ik schat dat ik niet zo veel nodig had, 5 of hooguit 10 mm. Voor 235 dan hé, voor 245 heb schat ik toch minimaal spacers van 10 mm nodig. misschien nog iets meer. Van de andere kant, de ET waarde van die BBS is een stukje lager, ik denk dat het met 10 wel lukt.
#9 Old 12-31-2014
Quoted: 9 Post(s)
One BBS in front of my current wheel. I was just curious how it looked
File Type: jpg 10888540_668400026612457_3707275571225951522_n.jpg (45.6 KB, 7 views)
#10 Old 01-16-2015
Quoted: 9 Post(s)
Update:
Both set of wheels fit. Only the front wheels slightly rub the fenders.
I'm gonna buy a new set of tires 225/35/19. I hope this will eliminate most rubbing problems.
Keep you posted.
Thanks.
Paul
SLK200 - biggest wheels you can comfortably fit? JazzanovaSLK General Modifications R171 5 10-02-2013 03:08 PM
Anyone know if the slk 350 amg pack wheels will fit an 06 CLK 350? sdshah3 General Discussion 9 01-12-2010 04:52 PM
18" AMG five star wheels from C350 fit SLK? casper SLK R171 General Discussion 5 06-15-2009 06:20 AM
SL AMG Wheels vs. SLK 55 Wheels MaKEuhigh AMGs 7 05-21-2009 07:19 PM
Set of 18 inch AMG wheels for sale, UK will777888 SLK Parts For Sale 3 01-01-2009 06:39 AM
