Wheel distance from brake caliber - Mercedes Benz SLK Forum
#1 Old 02-14-2011
Finn-SLK350's Avatar
Vehicle: MB SLK 350 7G tronic 2004, smarttop, greenfilters
Other Toys: Seadoo gti
I found nice wheels from ebay UK. The wheels are 19 front 8,5 ET35 and rear 9,5 ET38, so i think the ET should be ok, maybe 3mm spacers to front and rear.
But little concerned that is the wheel going to take contact for the brake calibers( in front wheels). So how much free space from wheel connection point and the wheel frame (horizontal) should minimum be?
And yes i can measure it my self, but car is outside and here is -32 degrees Feel quite bad for the car when i started i't in morning
Finn-SLK350 is offline
#2 Old 02-14-2011
-1-
Don - Founding Member #4
-1-'s Avatar
Offset is the key. I have 19" wheels on my SLK 55. Offset is 32 front and 35 rear. While the offset you stated is not ideal, they SHOULD work. SLK 55s with larger front calipers create the most problems with offset.
-1- is offline
#3 Old 02-14-2011
Thanks Don
#4 Old 02-14-2011
PropDr's Avatar
Quoted: 18 Post(s)
The offset should be ok.
For the frond to clear the caliper the wheel spokes should be close to the outer rim lip (look like for a FWD car)
My Beautiful Black Walkre (Valkyrie)
PropDr is offline
#5 Old 02-14-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
And no minimum distance as far as I can tell; the distance between the spokes and the caliper can be incredibly small. On my car with OEM brakes and OEM wheels, there is barely enough room to put a tooth-pick in.
Durkatlon is offline
#6 Old 02-14-2011
PropDr's Avatar
Quoted: 18 Post(s)
I would go for a minimum of 2mm to allow for thermal and flex.
PropDr is offline
#7 Old 02-15-2011
Thanks mates. Those wheels that i was looking are gone from ebay but there are other options also. Have to try to decide...and hopefully i have new wheels when snow starts to melt
#8 Old 03-02-2011
Ok i bought wheels and tyres and tested them today...and find out that front wheels take contact to brake calibers, so i tested the wheel with washers, and find out that with 10mm spacers the front wheels works, but the tyres and wheel come little too much out (i was going to use 3mm spacer to reduse offset to 32mm). Rear tyres came out about same than front with 10washers.
Front 19x8,5 ofset 35mm tyre 235 35 19
Rear 19x9,5 ofset 35mm tyre 265 30 19
I't seems that the tyres are going to rub the fenders, i have normal slk350 suspension, but i don't know is the suspension going so low that the tyres will rub the fender?
Now i have to think am i going to sell the wheels/tyres or will i try to drive them with 10mm spasers in front
http://img823.imageshack.us/i/02032011571.jpg/
http://img203.imageshack.us/i/02032011573.jpg/
http://img27.imageshack.us/i/02032011574.jpg/
http://img834.imageshack.us/i/02032011572.jpg/
http://img848.imageshack.us/i/02032011578.jpg/
#9 Old 03-02-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Ooh yeah, that's not a good look. Has a bit of that cholo low-rider vibe going on...
#10 Old 03-03-2011
i Checked the offset from the wheels and it was rear 35 and front was actually 32. so in paper all should be fine. Ok front takes to the brake calibers. But why the rear is coming so much out with right specs?
So to find the right wheels from ebay is not easy
#11 Old 03-13-2011
I tested one more time for the rear wheel, because i measured the wheel and calculated right specks with 35mm offset and found out that the wheel was correct. Ok and now the rear wheel worked fine, so first time when i was in hurry testing the wheel my wheel bolts where too long and bolts didnt tighten the wheel correct and when lowering the car with jacklift the wheel had been moved and thats why it seemed that it was coming too much out I wanted to tell that 19x9,5 et35 works fine with 265/30/19 in rear so that there would be no confusion when reading my posts.
#12 Old 03-13-2011
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Thanks for following up. Glad you got it sorted. How about some pictures of the final product?
#13 Old 03-13-2011
I sorted rear but the front still would need 10mm spacer in SLK350. So can't use those wheels
This pic the rear wheel properly in place
http://img860.imageshack.us/i/11032011590.jpg/
And this wheels just side of car, bad pick
http://img854.imageshack.us/i/08032011586.jpg/
So i have to buy new wheels have been thinkin the Axxion AX2 i think AX2 would work in front also. AX2 is not black from center.
Some how i like the look of those first wheels.
#14 Old 03-13-2011
PropDr's Avatar
Quoted: 18 Post(s)
Adding a 10mm spacer to a wheel with an offset of 32mm affectively changes it to 22mm.
PropDr is offline
#15 Old 03-13-2011
But the front wheel came too much out with that 10mm spacer it would have been rubbing the fender and thrown the dirt to cars sides
Maybe those wheels would work in SLK 200 with smaller brake calibers
#16 Old 03-13-2011
PropDr's Avatar
Quoted: 18 Post(s)
Dont make the same mistake. The AX2 is a BMW wheel.
BMW uses a C-Clamp like brake caliper with pistons only on the inside, so there is little caliper protrusion to the outside.
If you again need an 10mm spacer to clear the brakes you need to start out with a wheel offset of 45mm.
PropDr is offline
#17 Old 03-13-2011
I was asking those ET45 wheels but that seller didn't have those only 19x8,5xET32 to the front. I measured from my car that the wheel would need free space about 50mm from connection point to the wheel spokes.
So if i buy those AX2 wheels seller have to confirm me that there is minimum that 50mm free space. But i haven't decided yet what wheels i wan't, but it's hard to find good staggered wheels with the lip that fits SLK350.
Thanks for warning for those AX2
#18 Old 04-19-2011
Finally i got my new wheels
Wheels are Vertini Regency
Front 19x8,5 ET32 tyres Falken 235/35/19
Rear 19x9,5 ET35 tyres Falken 265/30/19
http://img823.imageshack.us/i/img2222oo.jpg/
http://img854.imageshack.us/i/img2212v.jpg/
And yes the car needs lowering maybe 35mm
#19 Old 04-19-2011
#20 Old 04-19-2011
PropDr's Avatar
Quoted: 18 Post(s)
Originally Posted by Finn-SLK350 View Post
Correction 265/30/19
You know, you can edit your post
PropDr is offline
Pre-Sale: The ultimate wheel cleaner in 5 Liter Refil DetailersDomain Caring for your SLK 0 06-03-2010 09:18 AM
The ultimate wheel cleaner? Sonax Wheel Cleaner DetailersDomain Caring for your SLK 5 04-06-2010 09:07 PM
