Cleaning 17 inchers - Mercedes Benz SLK Forum
  • 1 Post By johnr43
  • 1 Post By etyu
#1 Old 01-30-2011
nakulan7's Avatar
Vehicle: 08 SLK 55 AMG
Other Toys: Lexus IS250
Chats: 2
Quoted: 33 Post(s)
Cleaning 17 inchers
It is a right royal pain in the proverbial to clean the 17 inch rims on the 350. The Car wash doesnt clean it completely and i clean it by hand.
The back wheels are ok but the fronts have to be cleaned with moving the car forwards or backwards and cleaning the rim which is clear off the brakes.
Is the cleaning any easier on 18 inchers? Have to say that it is a bit tiresome and am thinking about getting pads which "dust" less.
nakulan7 is offline
#2 Old 01-30-2011
Swagman's Avatar
Vehicle: 12' SLK55 AMG
Other Toys: 15' HYUNDAI SANTA FE
Quoted: 36 Post(s)
Originally Posted by nakulan7 View Post
The Car wash doesnt clean it completely .
What !! Poor SLK
Swagman is offline
#3 Old 01-30-2011
-1-
Don - Founding Member #4
-1-'s Avatar
My wife's SLK 350 has the same wheels in 18". I can completely clean both front and back wheels, including inside, without moving the car.
-1- is offline
#4 Old 01-30-2011
Quoted: 6497 Post(s)
I clean my 18 5 twin spokes daily and knock all 4 off in under 10 mins total.
procedure:
wet paper,rag, etc
do inside of rim around
do lip of rim near tire and spaces in between
do each spoke big area
do each spoke inside each little area
do mb symbol amd outer spokes
maybe because I do it daily, it does not get a chance to get dirty
#5 Old 01-30-2011
Vehicle: 2004 SL500
Other Toys: Legos, tinker toys, blunt crayons, whiffle balls, and sponges...
A labor of love
This is a labor of love. I use a HAAN hand steamer I bought from Amazon dot com for about 65 USD. It makes the dust easier to remove with wheel cleaner and narrow brush. I polish as much of the area as I can reach. The polish helps subsequent dust wipe off more easily. But, I also wipe the outer parts of the spokes after each drive. I have 17" AMG 5 spoke wheels.
Bucket List likes this.
johnr43 is offline
#6 Old 01-31-2011
I use Meguair's wheel cleaning solution. It's a non-acid product that is safe for clear coats and painted wheels, diluted 1:4 in a spray bottle. This is available in pre-diluted form at most auto stores or in one-gallon concentrate from auto detail supply places. I spray the diluted solution unto the rims and clean them with worn/old household sponge and home-modified wheel brush before washing the car body.
I've modified a wheel cleaning brush using the one used to clean refrigerator cooling coils (available at Wal-Mart, Target or similar stores). Been using the same brush for more than three years on the 55. I cut the thin tapered end of the brush and re-attached the rubber tip securely. Use only gentle strokes to clean the rims and it will reach the whole depth of the rims and the brush has a small enough diameter to clear the space between the caliper and the rims. Others have used a soft brush used by motorcycle enthusiasts to clean the nooks and crannies of their engine. See also Brian_74"s post on how he cleaned the engine with the same soft-brisled brush.
See photos below. I am still using the same gallon-sized concentrate bought several years ago.
etyu is online now
#7 Old 01-31-2011
Vehicle: 2006 SLK 350 Designo (sold)
Other Toys: 2007 GL320CDI
When they are clean, get a nice application of car wax (paste) on them and then they will clean up lots easier, as this will keep the dust/dirt from adhering so tenaciously.
lkchris is offline
Rear Window Cleaning Gregg SLK R171 General Discussion 5 05-11-2010 12:33 AM
Cheap lug hole, rim/tire, and general cleaning tools johnr43 SLK R171 General Discussion 1 02-24-2010 07:49 PM
Cleaning Green Filters..... discodan General Modifications R171 3 10-11-2008 10:21 PM
Cleaning Back Window??? shpritz SLK R171 General Discussion 5 07-22-2007 03:22 PM
