Speed Sensor Location? - Mercedes Benz SLK Forum
#1 Old 01-10-2011
Vehicle: 2006 SLK55
Other Toys: BMW X5 50i
I understand that the speed that shows up on the speedometer is registered from the number of times the wheels spin.
Does anyone know which axle the computer is analyzing?
rkleung is offline
#2 Old 01-10-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
On the R171, it's looking at all four wheels, but I don't have any idea what formula it's using to calculate a final value.
UK-C200 is offline
#3 Old 01-11-2011
Vehicle: 07' slk 55
Other Toys: 93' turbo supra 430whp
the esp module looks at all the wheelspeeds and determines the true speed, then sends it over can to the cluster/m.e. and whatever else wants to know. This is how some of the benz's can determine if a tire has low pressure it notices when the car is going straight one of the tires has a significantly higher rpm due to smaller diameter of a tire low on air. This is before they were using tpc. it also uses that same logic and looks at your steering angle sensor and if it sees a certain steering angle say 10 degrees off and notices all the wheels have identical speeds it will throw a esp code- so you have to get an alignment done.
roadtalontsi is offline
The Following User Says Thank You to roadtalontsi For This Useful Post:
Tire Speed Ratings Titus Tires, Wheels, Brakes & Suspension 31 05-10-2012 01:29 PM
Smart top speed adi General Discussion 13 08-15-2010 05:58 PM
Please Advise, Did your SLK come with Y speed or W Speed Tires? mb911 SLK R171 General Discussion 20 07-21-2010 10:42 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
Speed Indicator in Km/h - can this be changed? BiigJiim SLK R171 General Discussion 6 12-14-2007 06:28 AM
