18" wheels onto a 200K - Mercedes Benz SLK Forum
 7Likes
  • 5 Post By bigsteve
  • 2 Post By bigsteve
#1 Old 11-21-2014
Vehicle: 2005 slk 200k
Other Toys: Triumph 1050 tiger SE
Hi just thought I would post my 18" wheel upgrade information as I did a lot of reading on this forum before I went ahead.
So wanted to up grade from std 16" to 18" but did not like the most merc wheels or could not afford the AMG one's I did like.
So being a 55 year old boy racer ( well in my head) went to the aftermarket world. I wanted some deep dish style wheels.
After a month I found these wheels for sale off a CLS500,they were originally sold in the UK by Wolfrace Wheels under the name Shark but are actually Ruff racing wheels, brought this set via ebay and I assumed they were polished alloy but the outer rim is a stainless steel bonded on trim.
They are 8.5 and 9.5 ET35 x 18 rims which the forum said would fit.
They do fit but not with out some minor issues, had to change the tyres to 225/40/18 front ( contacts 5) and the rear to 255/35/18 ( also contacts)
The first issue is I needed 60 degree wheel bolts as Merc one are raidus ones and will not fit, I used 25mm long bolts for these wheels, original bolt hole are for 14mm bolts but I use M12 bolts but again checked on forum and that said it was OK as long as the wheel bolt fills the full tappered hole, which they do.
On first fitting rears all OK clearance all round JUST
Fitting the fronts they locked up on the tyre against the strut leg, this because the Contact 5 have a rim protector moulded on the tyre and it sticks out a few mm, so dug out a old set of 3mm spacers, problem cured with no issues on full lock, with different tyre you may not have this issue.
The wheel centres on the rear were OK but the front would not fit due the the grease cap coming through the wheel centre.
So after a dig through my steel stock box of old off cuts found some 66mm tube which I cut off 2 x 7mm rings, which I painted silver and bonded in to the wheel and then fitted the centre cap over that.
So bit of mucking about but OK, so the thanks to the forums for all the info which proved to be all good and big 18" will fit on a 200K
bigsteve is offline
#2 Old 11-21-2014
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
They look really nice.
We want more pictures with more light
  • AirMadZ Air Suspension
  • Accuair eLevel Suspension Management
  • 19" OZ Superleggera IIIs
  • Michelin Pilot Super Sport
  • Wheel Setup Front: 225x35x19 - 8,5J - ET30
  • Wheel Setup Rear: 245x30x19 - 9,5J - ET20
  • SLK350 Brake Upgrade
  • Smarttop
OffLineR is offline
#3 Old 11-21-2014
Ah that will be a camera phone and grey British weather I will wait until the sun comes out so that could be some time. LOL
yes added a Wow factor to the look of the car, standard wheels are not great.
Car is lowered by 30mm too.
Make's getting a jack under it a pain.
I need to leave it alone now.
bigsteve is offline
#4 Old 11-21-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Very nice wheels. They look great on the lowered car.
Durkatlon is offline
#5 Old 11-22-2014
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 930 Post(s)
My car came from factory ( according to my dacata card ) with 21" ( kompresor 200 ) and now i have 18". I do love the fat tires =)
i860 is offline
#6 Old 11-22-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
Very nice !
curro101 is offline
#7 Old 11-22-2014
AZ SLK's Avatar
Vehicle: 2007 MB SLK 280, Remus Exhaust, TSR 17" wheels, Pirelli PZero tires
Other Toys: '15 Z51 Corvette, '12 Cadillac Escalade EXT, '11 MB GLK350, '04 Honda GoldWing, '13 Craftsman VT4000
Quoted: 25 Post(s)
Nice job - thinking outside the box and a little ingenuity produced a beautiful outcome.
Michael --
AZ SLK is offline
#8 Old 11-24-2014
Hi
Thanks for the positive comments, yes well pleased now added some stick on 3D wheel centres that finish the job ( not flat printed ones)
Sun came out so some more photos still a camera phone though.
You can now see the lowered stance better.
Durkatlon and OffLineR like this.
bigsteve is offline
#9 Old 11-24-2014
Vehicle: Black 2011 slk 300
Other Toys: cars, motorcycles dirt and street, quads
LOOKS GREAT. Deep dish is always worth the headache.
SLK300sport is offline
#10 Old 11-25-2014
VTBlade's Avatar
Vehicle: 2002 SLK 230k
Quoted: 14 Post(s)
Nice bit of DIY. Great result. As above, I also like the deep dish look - makes the car appear much fatter (or is that phatter for boy racers?) Nice aggressive look with the lowered suspension.
VTBlade is offline
#11 Old 11-25-2014
Vehicle: 2014 SLK250
Quoted: 271 Post(s)
I used these wheels on one of my SLs - two things you might want to consider: fitting ceramic pads as the black dust gathering around the imitation rim bolts is a pig to clean, and Shark supply domed wheel caps that might look more the part than making them up. Not expensive iirc.
Hal Adams is offline
#12 Old 11-26-2014
contact details
Hi Hal
do you have any contact details on the wheel center suppliers still, as I cant find anything about them.
Steve
bigsteve is offline
#13 Old 11-27-2014
Quoted: 271 Post(s)
Now you are taxing my memory!
But a stroke of luck - I googled Wolfrace wheels to see if any supplier names jogged my memory, and lo and behold in the images was a photo of my old SL with the wheels fitted showing the supplier in the accompanying thread! So try here:
Wolfrace Shark Black Alloy Wheels | Wolfrace Shark Black Alloys
They were certainly helpful at the time. Of course, you could always contact Wolfrace Wheels direct and see what they have, as the Shark wheel is one of their old designs (better than their new ones, imo...) that they now confine to trade sales.
I had a sneaking feeling that when I sold the wheels, I held onto the caps for some reason. I just had a quick look, but cannot find them. I will hunt again when the light is better and let you know if I do find them.
As for the pads, two makes I have tried are Akebono and EBC Redstuff. Akebono are really good, but for some odd reason hard to come by in the UK. I brought mine in from the States until the customs nabbed me on one loty for unreasonable duty (I think that godam Blair needed money to fight one of these ridiculous wars at the time!) So I moved to EBC Redstuff which I found perfectly good - and, as I say a must for those little bolt heads. Believe me there is nothing worse that split rims or imitation split rims where black dust has gathered around them.
#14 Old 11-27-2014
thanks
Hi Hal
I have emailed them , but if you find yours please let me know.
Steve
bigsteve is offline
RH Wheels - 18" - Black mstefani SLK Parts For Sale 0 04-05-2012 11:39 AM
18" AMG Wheels for sale themizz039 SLK Parts For Sale 0 12-28-2011 02:57 PM
FS: 18" Kleemann wheels Ynot General Discussion 4 05-27-2007 10:24 AM
