SLK55 Tire Change Question, help - Mercedes Benz SLK Forum
#1 Old 01-07-2011
Vehicle: SLK55 2008
Other Toys: Porsche 911, BMW X5
One of my rear tires has a wear on the inside and need to change the rears on my slk55, the tires are the OEM Pirelli P Zero, the dealor is asking $380 for each plus install. Discount Tire is around $302 for each.
My question is I have TPMS in the car, so is that something that is with the tire or the stem on the rims. By changing the tires from Discount tire or tirerack would I need to order anything additional for the TPMS to function properly? or the tire change would not mess that up?
thanks.
effusion_01 is offline
#2 Old 01-07-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Mercedes TPMS is in the valve stem. Common practice, however is to replace when you change the tires, as the batteries do wear out. I *think* the MB recommendation is every 3 years?
UK-C200 is offline
#3 Old 01-07-2011
Vehicle: SLK55 2008
Thanks for the quick reply, wonder when they charge $380 for a tire if the valve stem is included or thats an additional.
#4 Old 01-07-2011
PropDr's Avatar
Quoted: 18 Post(s)
The TPMS batteries should be good for 7 to 10 years.
A good tire shop will replace the o-ring for the TPMS at every tire change.
My Beautiful Black Walkre (Valkyrie)
PropDr is offline
#5 Old 01-07-2011
aka John
Chats: 1143
Quoted: 30 Post(s)
Yeah, not sure where I read two years - Schrader's documentation says 5-7, so should be good. They do say to replace the valve stem..
UK-C200 is offline
#6 Old 01-08-2011
Vehicle: SLK55AMG
Other Toys: Triumph T800
Are you guys sure an slk uses sensors bececause mine doesnt so i think you are mistaken or US cars are different, SL55 use them I think but that older technology. I fit my own tyres and use std valves I can guarantee that. Sensors are not reqd for tire pressure measurement because the abs sensors measure each wheel and an algorithm detects differences in relative speed and of course rolling radius changes with pressure. This is why the tyre system has to reset periodically, if it was measuring pressure then a reset wouldnt be required as its fixed
Legin is offline
#7 Old 01-08-2011
richard_leeds's Avatar
Vehicle: 05 350 Auto
Other Toys: Volvo XC60, Panda 4x4, mountain bike, kite, toddler
Chats: 4
Quoted: 8 Post(s)
Hi Legin
Yes, the systems that detect a flat tyre measure the wheel rotation. However there is a more detailed system that will display the actual tyre pressure on the dashboard, that uses a wireless sensor.
John has retrofitted his, look at this pic of his dashboard, and the discussion in the posts that follow ... https://www.slkworld.com/general-modi...tml#post202483
richard_leeds is offline
#8 Old 01-08-2011
Vehicle: SLK55AMG
Ah thanks for that all is clear to me now
Legin is offline
#9 Old 01-08-2011
Vehicle: 2010 SLK 350
Discount Tire (DT) price includes everything. BTW, DT will price match Tire Rack. For me, TD charges the TR rack price + shipping + DT's installation price ($12.50/wheel), and no sales tax (you didn't pay TR any).
One warning, although I have have nothing but praise for DT, I'd check into how they plan to raise the car. You don't want the AMG plastic damaged.
Mr Mojo is offline
#10 Old 01-08-2011
PropDr's Avatar
Quoted: 18 Post(s)
My car has OEM TPS units installed; it will alarm is the pressure on any tire gets out of a preset range.
It has two warnings, one for pressure and one for system problems.
PropDr is offline
#11 Old 01-08-2011
Last time I had my tires changed at Discount Tire, technician states it is routine to change the O-rings of the TPMS (valve stem mounted), otherwise they will not guarantee against air leaks from the tire installation. IIRC the valve-steim mounted TPMS became standard on model year 2008 US vehicles.
Earlier models uses software as TPMS, based on rotational forces of the wheels (tire+rim).
#12 Old 01-13-2011
Vehicle: 07' slk 55
Other Toys: 93' turbo supra 430whp
yes u.s. cars are different. All 08'+ cars regardless of make or model require a tire pressure monitoring system. The actual sensor attaches to the valve stem, but you can get the stem separately- costs around 30$. The older sensors are good for approx 96month but you never know. the dealer charges alot for tires because its for your convience, tires take up alot of space and they dont get nearly the same hookup on them as a tire only shop.
roadtalontsi is offline
The Following User Says Thank You to roadtalontsi For This Useful Post:
#13 Old 01-14-2011
Confirmed
Using America's Tire Co. website (under Did you find a better price), cut and paste the URL from Tire Rack to show the price per tire and submitted together with contact info to local America's Tire Co. I got a call from the store manager stating they will match by backing off the price of the tire, to account for sales tax and shipping - essentially bringing the price point to be the same as Tire Rack.
Will be going in next week for 4th set of rear tires (trying out Prop Dr's recommendation -- Hankook Ventus Evo, 255/35-18).
#14 Old 01-14-2011
PropDr's Avatar
Quoted: 18 Post(s)
Looking forward to your evaluation!
PropDr is offline
#15 Old 01-15-2011
Vehicle: SLK55 2008
Well got my tires done, first it seemed the dealor was the only one with the tires in stock, also when I just went in to the dealership they gave me a total different price than when on phone. They turned out to be much cheaper than DT in the end so just got it done.
Oil Change Question razr-01 SLK R171 General Discussion 12 01-06-2011 08:44 PM
Tire Pressure Question Medescape Tires, Wheels, Brakes & Suspension 5 06-26-2010 06:02 PM
Max tire size for 18 inch rear tires on SLK55 AMG netmiami AMGs 9 06-07-2010 12:37 PM
Rear tire sizes & fitment question?? Catchmefucan Tires, Wheels, Brakes & Suspension 12 01-31-2010 05:27 PM
spare tire question Brian_74 Tires, Wheels, Brakes & Suspension 23 05-22-2009 02:58 PM
