Installed rear tires PROBLEM PLEASE HELP ! - Mercedes Benz SLK Forum
#1 Old 09-15-2014
Vehicle: 2007 SLK55 AMG
Other Toys: S2000
Car 2007 SLK55 AMG
RIMS STOCK 18' AMG
TIRES INSTALLED REAR 255-35-ZR18
HANKOOK ventus v12 evo2
we did an alignment and installed the tires only rear the front is still on the michelin..
the problem is that the car now feels like the rear end is floating almost like i have no traction on the rear, on the freeway if a slight turn comes up it feels like the rear wants to come around.. if you make a right or left turn like a freeway on ramp and lets say 10 mph over the speed limit the traction light starts to blink..
the rear end feels really loose .. can anyone give me pointers on what the issue might be? i will be taking the car back to the alignment shop to make sure they did not set the toe incorrect ..
thanks for the help in advance !
Red_90teg is offline
#2 Old 09-15-2014
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Rear tire pressure too high ..?
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#3 Old 09-15-2014
Other Toys: S2000
i will check in the AM..
is there a reason the stock tires are " extra load" ?
#4 Old 09-15-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
As Sean said , check the pressures and also that the tyres are mounted in the right direction ( wierder things have happened ) !
curro101 is offline
#5 Old 09-15-2014
Braveheart20's Avatar
Vehicle: 2014 slk amg polar white command online
Other Toys: quad bike jet ski range rover sport, mini countryman.
Chats: 4
I had a similar experience with my 2010 slk 55 3.5 mm left on rears. However I felt I was driving a car with no tread on the rear, garage checked out suspension etc nothing un towards. I ended up putting two new tyres back on rear this resolved the issue.
Then traded the car in for the 172 slk 55.
Probably doesn't help your issue but very similar posting.
Brave heart
Braveheart20 is offline
#6 Old 09-15-2014
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
What size tires on the front. If there is a difference in circumstance greater than 3% will cause traction control light to come on.
Gbarringer100 is offline
#7 Old 09-15-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Those tires are fine. I'm on my fifth set of those on my SLK. Agree with the points already raised: over-inflation, mounted the wrong way (note the directional arrow on the sidewall) are most likely causes. Although overinflation causing that much traction loss seems odd.
The 3% rotational speed difference causing traction control warning is a possibility if you have a tire with a very stiff sidewall on the front (since the Hankooks are known to have comparitively soft sidewall). But that would not explain the floating sensation you're getting and the absolutely lack of traction in the rear.
Durkatlon is offline
#8 Old 09-15-2014
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 123 Post(s)
Where in CA? What's the outside temp?
The only other thing I can think of is they need to be run in a bit..
FUN 4 2
Der Flieger is offline
#9 Old 09-15-2014
Other Toys: S2000
TIRE PRESSURE 42 DRIVERS SIDE ( temps taken car parked outside but not driven)
TIRE PRESSURE 41 PASS SIDE
Tires are mounted correct
- so cal its about 100 outside right now
Front tires are Michelin pilot super sport
225-40-zr18
i still have not taken the car back to the shop to check rear alignment incase he did a bad job..
thanks for all the support guys !
#10 Old 09-15-2014
Quoted: 99 Post(s)
Your rear and front tires are around 0.3% difference so you are ok. Yes *I would have the alignment checked. When I got my car I noticed the rear was funny when hitting a bad spot in pavement. Worn new tires out in 4k miles. Got new tires and the alignment turn out on the rear to be way off. New alignment and the rear settled down.
#11 Old 09-15-2014
Vehicle: 2005 SLK 350
I had Michelin Pilot Super Sport (summer tire) put on all four corners of my 05 slk350. Car handled great (when it was warm outside).
Like everybody else, the rears wore out before the fronts. Because I didn't like how quickly the Michelin rears wore out, I replaced the rears with Continental Extreme Contact DWS (all season tire).
When I did that, the result in the way the car handled was exactly the way you described your car in post #1 . It felt so unstable and unsafe, I put matching Continentals on the front. Getting matching tires on front and back solved my problems. The handling returned to normal.
My case may be different than yours because I mixed summer and all season tires, and I think your Hankooks are summer tires like your Michelins.
I believe the key is to have tires that have equal performance abilities on both ends of your car. To my mind, the only way to insure that is to have same brand and style on all four corners.
I am certainly no tire expert....just my opinion.
Hilltopper is offline
#12 Old 09-16-2014
Other Toys: S2000
does it make a difference if its a run flat? it almost seems like the side wall is too soft and its flexing.. while the front tire feels to have more of a strong sidewall like a road race tire..?
#13 Old 09-16-2014
Quoted: 99 Post(s)
Soft sidewalls can give you some side to side movement.
#14 Old 09-16-2014
Other Toys: S2000
Brought the car in for inspection .. Lets see what the tech says..
#15 Old 09-16-2014
Naffdave's Avatar
Vehicle: 2005 SLK 280 7 Speed Tiptronic In Silver
Other Toys: NSM Sattilite Jukebox
Quoted: 22 Post(s)
Send a message via Yahoo to Naffdave
Ive just done the same on my 280 tho im on 17'' rims put new Hankooks on the rear and left Michelins on front totally transformed my car handles beautifully and is smoother and quieter on the road. Im surprised you have problems as the Hankooks are very good tyres.
Dave
Naffdave is offline
#16 Old 09-16-2014
M4rCu5's Avatar
Quoted: 234 Post(s)
What he say, couple hundred miles of "fun", take the shine off of the tread
M4rCu5 is online now
#17 Old 09-18-2014
Other Toys: S2000
problem solved.. they were too new ! i guess the traction light coming on threw me off.. my s2000 has no traction control so I'm not usto it..
The Following User Says Thank You to Red_90teg For This Useful Post:
#18 Old 09-19-2014
Quoted: 123 Post(s)
you're welcome... wink
FUN 4 2
#19 Old 09-19-2014
M4rCu5's Avatar
Quoted: 234 Post(s)
LOL .. ditto
Rear Quarter window preventing a problem dweeb4 SLK R170 General Discussion 7 07-08-2016 10:34 AM
Rear defrost problem cd22 SLK R170 General Discussion 5 07-14-2014 06:43 AM
rear camera problem Slk55nor SLK R172 General Discussion 0 03-09-2014 12:37 PM
max size tires on rear r172 slk_baby General Modifications R172 6 02-24-2014 04:35 PM
New Tires on the rear paultalb AMGs 11 03-17-2011 08:40 AM
