What Rear Tires To Purchase? - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By Beekster
  • 1 Post By fastdawg1
#1 Old 08-03-2014
Vehicle: 2007 SLK 350
The tread on my rear tires is warn out, so I'm in need of some new tires. I'm looking at the following all-season tires from Costco:
Bridgestone - Potenza RE97AS (45k miles manufacturer warranty) $140/each
Michelin - Pilot® Sport A/S 3 (45k miles manufacturer warranty) $159/each
Michelin - Primacy™ MXM4 (45k miles manufacturer warranty) $177/each
Bridgestone - Potenza RE970AS Pole Position (40k miles manufacturer warranty) $143/each
Which ones would you guys suggest?
Thanks!
aj9079 is offline
#2 Old 08-04-2014
Beekster's Avatar
Quoted: 164 Post(s)
What brand are your front tires? It's not a good idea to mix tire brands, as differences in construction & performance can lead to some bizarre handling quirks.
That aside, the Michelin Pilot Sports are very nice tires, as are the Bridgestone Pole Positions. I haven't owned either of these specific models, but have owned earlier versions of the Pilot Sport family and been quite happy with them.
LewSLK likes this.
Beekster is offline
The Following User Says Thank You to Beekster For This Useful Post:
#3 Old 08-04-2014
Mensra's Avatar
Quoted: 385 Post(s)
Better check those warranties. Most require rotation front to rear to be valid. Some cut the warranty in half if not rotated, if they even will warranty for wear.
Mensra is offline
The Following User Says Thank You to Mensra For This Useful Post:
#4 Old 08-04-2014
Beekster's Avatar
Quoted: 164 Post(s)
Rotating isn't possible on the SLK, at least not in North America. The tire sizes and wheel widths are different F/R, and most tires are directional so they can't be swapped L/R without dismounting them from the rims. Given that, it seems that few SLK owners attempt to rotate their tires and simply drive them until they need replacement. It's a sports car, after all, so getting a lot of mileage out of the tires usually isn't a key criterion for purchase; traction usually is.
LewSLK likes this.
Beekster is offline
#5 Old 08-04-2014
Thanks for the replies guys! I called costco. They said the warranty will be cut in half. The front tires are michelin mxm4.
aj9079 is offline
#6 Old 08-04-2014
Other Toys: 2014 SL 550
Quoted: 11 Post(s)
Michelin Pilot Sport A/S 3
I just put them on. I removed Yokohama Avid Envigor tires.
You will be very happy with the A/S 3.
LJ12530 is offline
The Following User Says Thank You to LJ12530 For This Useful Post:
#7 Old 08-05-2014
Beekster's Avatar
Quoted: 164 Post(s)
If your budget allows, replace all four. The MXM is a Touring tire; it doesn't have the grip that the Pilot Sport AS3 does. I suspect that you'll induce an understeer condition at the front by mixing the two tire models; the MXMs will reach their grip limits well before the Pilot Sports do. Costco also usually has a rebate coupon for $70 or so when purchasing four instead of two.
Beekster is offline
#8 Old 08-06-2014
My front tires are mxm4 and they have a lot of tread left in them.
So, should I get new mxm4 tires just for the rear or do I absolutely need to change all four tires?
Btw, I'm on a budget
aj9079 is offline
#9 Old 08-06-2014
Beekster's Avatar
Quoted: 164 Post(s)
Well, the way forward then is probably to fit MXMs in the rear. The car won't feel as sure-footed as with the PS3s, but there's no harm in it.
Beekster is offline
#10 Old 08-09-2014
ZeroZero's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 256 Post(s)
Thumbs down
Hi all
I'm not sure having different brands front & rear will make the car handle poorly , I would say some brands are better suited at the front & some at the rear
Andy
ZeroZero is offline
#11 Old 08-09-2014
Beekster's Avatar
Quoted: 164 Post(s)
Hi all
Andy
Perhaps so, but Daimler-Benz doesn't mix brands on different ends of the car when they build it and in this case I'll assume that they know best.
Beekster is offline
#12 Old 08-11-2014
ponia003's Avatar
Vehicle: 2006 SLK280, 2005 E500 (W211)
Other Toys: Horses
Quoted: 29 Post(s)
I second Beekster here.
My first choice would be new Pilot Sports on all 4 corners. If that's not possible for budget reasons, I would mount MXM4s on the rear.
It's entirely possible that mixing makes/models/wear levels of tires would have no ill effect, but I would not do it given the choice.
Dan
2006 SLK280
Engine: 272.942 V6
Options: Iridium Silver Paint, Harmon Kardon Sound System, Heated Seats, Air Scarf, Vavona Wood Trim
Modifications: 18" AMG wheels, Brembo Sport Pack Front Rotors and Calipers, 290 mm Rear Rotors and Calipers, SmartTop, Akebono Ceramic Brake Pads, Mid-Size R171 Facelift Antenna, Clear Sidemarkers, Chrome Turn Signal Bulbs, Mercedes Star Valve Stem Caps, Custom Cabin Air Intake Screen, AMG Tinted Tail Lights and 3rd Brake Light, Xenon Low Beams, OEM Sport Air Cleaner with Custom Port Screens, LED License Plate Lights, LED Parking Lights, Lamin-X Fog Light Films
ponia003 is offline
#13 Old 08-11-2014
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 94 Post(s)
Unless you're going to test the performance limits often on your car, go cheap within reason.
Think about this for a second, you're going to change your back tires more than likely more often than you're scheduled to change your oil. Oil Changes are 10,500 miles, tires on the back last about 8,000 miles. The only thing would vary that thought process is if you drive low miles per year. Now if you're going to really be getting on your car or tracking it, then go with better tires.
Just my thought.
Gbarringer100 likes this.
fastdawg1 is offline
#14 Old 08-14-2014
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 925 Post(s)
I had to change my rear tire and got a pair of Uniroyal Rainsport 3.
Based on this report oar ok's
255 35 18 Tyres reviews - TyreReviews
i860 is online now
SLK 280 18" Chrome Rims w/ Toyo Proxes T1R Tires - 5k miles / Central NJ USA madvex SLK Parts For Sale 5 02-26-2012 04:39 PM
07 slk55: ok to have diff tires front / rear? esqdg AMGs 19 05-21-2011 02:45 PM
Max tire size for 18 inch rear tires on SLK55 AMG netmiami AMGs 9 06-07-2010 12:37 PM
rear tires neurotrash AMGs 17 06-09-2009 01:49 AM
need help on choosing rear tires etyu SLK R171 General Discussion 9 09-09-2008 04:52 PM
