Tyres (SLK 350) - Mercedes Benz SLK Forum
 18Likes
#1 Old 05-14-2014
Vehicle: SLK350 Auto 2005
Other Toys: Honda CR-V 2.0 SE
Quoted: 28 Post(s)
Tyres (SLK 350)
Just been cleaning my car and putting air in the tyres and noticed that my front tyres are:
225/45 R17
And my rear tyres are:
245/45 R17
Isn't this illegal (UK)?
Joe
Well having just read the information on my data card and it says:
17" LIGHT ALLOY WHEEL 10-SPOKE DES. W/ MIXED TIRES
Mixed tyres must be ok then.
joemackem is offline
#2 Old 05-14-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
225/45 R17
245/45 R17
Joe
Those are the stock sizes. The wheels themselves are also 7.5" wide on the front and 8.5" on the rear, with tires on the rear 2 cm wider than on the front, to match.
joemackem likes this.
Durkatlon is offline
#3 Old 05-14-2014
Quoted: 28 Post(s)
Cheers, thanks for the reply.
Joe
#4 Old 05-15-2014
Vehicle: SLK 350 2005
think they are supposed to be 245/40 on the back
dcmulford is offline
#5 Old 05-15-2014
Roy350's Avatar
Quoted: 26 Post(s)
Yep, thats as it should be.... So no front rear rotations
Oh and the rears will cost you 60 more than the fronts
Roy350 is offline
#6 Old 05-15-2014
GeeJay's Avatar
Chats: 91
Quoted: 70 Post(s)
As mentioned by dcmulford, should be lower profile on the rear to compensate for the wider tyre, maintaining the side wall height. But yes they should be different widths.
GeeJay is offline
#7 Old 05-21-2014
Vehicle: slk 200 kompresor 1.8
Other Toys: n/a
Quoted: 13 Post(s)
hi chaps why are the tyer profile 40 on the back and 45 on the front is this for the handling .
bossmck is offline
#8 Old 05-21-2014
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
Because the rear are wider. To keep the same circumstance the percent of width would be different. Tire size is tread width, the percent of tread width, and rim size. Example (245x40x17) 245 is tread width, 40 is 40% of 245 and the rim is 17. Hope this helps.
Roy350, Terentius55 and joemackem like this.
Gbarringer100 is offline
#9 Old 05-21-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
225/45 R17
245/45 R17
Joe
If these sizes are right , 245/45/17 on the rear and not 245/40/17 , you'll more than likely have ABS/ESP and cruise control faults !
curro101 is offline
#10 Old 05-22-2014
Vehicle: 2005 SLK350
Other Toys: ML350
I have 245/45/17 for more than 6 months with no errors.
feedback is offline
#11 Old 05-23-2014
curro101's Avatar
Quoted: 528 Post(s)
Have you tried the cruise control ?
curro101 is offline
#12 Old 05-23-2014
Roy350's Avatar
Quoted: 26 Post(s)
Gbarringer100's info is correct.
The wheel/tyre diameter should be the the same front and rear ie. the sidewall height should be the same at 100ish mm.
So for the front the sidewall height is 225/100x40 = 101.25mm, for rear 245/100x40 = 98mm which is near enough. If you have 45's on the rear the sidewall height will increase to 110mm increasing the overall wheel diameter by 20mm compared to the front.
If it could cause ABS/ESP/TPMS errors it's most likely do so if the fronts were worn and the rears were new, this would make for the largest differential in diameters.
Here's the sizes for 16/17/18 and 19 rims for the slk350.
Front : 205/55Z16 | Rear : 225/50Z16
Front : 225/45W17 | Rear : 245/40W17
Front : 225/40Y18 | Rear : 245/35Y18
Front : 225/35Y19 | Rear : 255/30Y19
Personally I wouldn't worry about it unless it did cause ABS type errors which I doubt it will. Handling may feel a bit different as the centre of gravity will be higher on the rear and the tyres will be a little more 'squishy' but it's probably going to be a marginal change.
Roy
Roy350 is offline
#13 Old 05-23-2014
Quoted: 28 Post(s)
I hope not as I've only had the car about 2 months, but yes these are right according to my data card for my car.
Joe
#14 Old 05-23-2014
curro101's Avatar
Quoted: 528 Post(s)
When I bought my car they put new tyres on the rear , size 245/45/17 , I then spent all afternoon trying to find out why the cruise control didn't work , when they were changed to 245/40/17 , everything was sorted !
curro101 is offline
#15 Old 05-23-2014
Quoted: 99 Post(s)
Comparing 225x45x17 to 245x45x17 has a difference in Circumference of 1.2% with in the MB allowance of 3%. You should not have any problems.
#16 Old 05-23-2014
curro101's Avatar
Quoted: 528 Post(s)
The difference is 2.84% , maybe in my case , new tyres / tyre pressure on the rear , had something to do with it affecting the cruise control , the only thing I know is that when I changed them to 245/40/17 the cruise control worked fine ..
curro101 is offline
#17 Old 05-23-2014
Other Toys: ML350
Yes, I did and as I stated, no errors.
feedback is offline
#18 Old 05-24-2014
Roy350's Avatar
Quoted: 26 Post(s)
Neat calculator !
Here's the difference between what is and what should be
The difference with 45 profiles on the rear is getting pretty near that 3% differential. If the front tyres were worn down 2mm more than the rears the difference would then be 3.5% so it's not surprising that different outcomes arise on different cars - it all depends front tyre wear.
Gbarringer100 -I was curious as to where you found that info about 3% differential allowance?
Also interested to find how the road speed is measured, is it derived from ABS sensors or propshaft speed?
Roy350 is offline
#19 Old 05-24-2014
Quoted: 99 Post(s)
The 3% was been in many post by other owners on this site over the years. Do not know what MB publication states this percent. Must be true based on owners who exceed the 3% and the cruise stops working.
There are sensors at each wheel that checks the speed of each wheel. In fact this is one way the low pressure tire warning work on some cars. A tire at low pressure will turn at a different speed and the light will come on. These will sensors will turn off cruise control if the speed of one tire is more than the 3% difference.
Here is a site to check the tire sizes. Note this site also allows to put in the rim sizes which can effect the Circumference of the tire. Plus you can see what the off set does in the fit on the car.
http://www.rimsntires.com/specspro.jsp
#20 Old 05-25-2014
Roy350's Avatar
Quoted: 26 Post(s)
I've never seen it in an MB document either, but 3% sounds plausible as wear difference between tyres only makes about 1% difference to the correct tyre setup.
My wifes car (mk5 GTi) uses that type of TPMS system, as you say it works on the basis that at low pressure the tyre is smaller in diameter and therefore rotates more [over a given distance]than the other [normal pressure] tyres.
That calculator is amazing - I'm off to play....
Roy350 is offline
SLK 350 & 55 back to back comparison mcat SLK R171 General Discussion 8 05-20-2008 04:29 PM
