Another wheel inquiry - Mercedes Benz SLK Forum
#1 Old 04-21-2014
Mr.Antwerp's Avatar
Vehicle: 2006 SLK 280
Other Toys: 2012 Grand Caravan - Irish Wolfhound Doggy Van :-)
Quoted: 37 Post(s)
Question Wheel Feedback Pls
I'm considering getting new fancy wheels for our 06 SLK280
Due to the fact that we got the car a few months ago with new tires, I would like to stick with the 16" wheels (also like the comfort ride of the 16" wheels & Michelin tires combination)
OEM wheels front is 7 x 16 Offset 34 - 205/55x16 Tires
OEM wheels rear is 8 x 16 Offset 30 - 225/50x16 Tires
Wheels I'm looking into are 7.5 x 16 Offset 35 - Hub Bore 66.56
As per Wheel Offset Calculator - Current Wheels Specs compared to New Wheel Specs I have following results:
Front - Inner clearance 7 mm LESS (the inside of the wheel to the strut housing) & outer position EXTEND an extra 5 mm (position of the outside edge of the wheel)
Rear - Inner clearance 1 mm MORE (the inside of the wheel to the strut housing) & outer position RETRACT by 11 mm (position of the outside edge of the wheel)
I wonder if I'll run into any issues when I'll get this set of 7.5x16 wheels with the 35 offset? - Please advise
Mr.Antwerp is offline
Changing the steering wheel, or otherwise know as I like a challenge now and then… Seanhump General Modifications R171 127 03-01-2019 07:08 PM
The ultimate wheel cleaner? Sonax Wheel Cleaner DetailersDomain Caring for your SLK 5 04-06-2010 09:07 PM
