Can CLK63 BS wheels be made to fit? - Mercedes Benz SLK Forum
#1 Old 03-27-2014
jameslk55's Avatar
Vehicle: 2005 SLK55 AMG
Quoted: 17 Post(s)
I'm trying to get to the bottom of this and understand it, once and for all. Unfortunately I know nothing about wheel fitments. I've been told that they don't fit the SLK. Why do they not fit and what can be done to make them fit?
Bolt Pattern: 5x112
Front Wheel: 19x9 ET21 (part# 2094015602); 24lbs?
Front Tire: 265/30R19
Rear Wheel: 19x9.5 ET31 (part# 2094015502); 28lbs?
Rear Tire: 285/30R19
jameslk55 is offline
#2 Old 03-27-2014
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Quoted: 528 Post(s)
From here :
http://www.alloywheelsdirect.net/inf.../mercedes-benz
The rim sizes should be : 19 x 8.5 ET 30 front and 19 x 9.5 ET 35 rear for Brabus rims ( 8.5 ET 28 & 10 ET 35 Carlsson )
Looking at the equivalents here :
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
The difference at the front would be , 3mm more inner clearance and 15mm more towards the outside ( 1mm more inside , 13mm more outside for Carlsson ) .
The difference at the rear would be , 4mm more inner clearence and 4mm more towards the outside ( 8mm more inside , 4mm less outside for Carlsson ) .
These results are for 225/235 fronts and 255/265 rears , so your tyre sizes would change the results slightly making the ouside measurements even greater and possibly rubbing on the inside ...
If the results were negative for the inner measurements , you could use spacers , but being positive you can't really do anything ...
curro101 is offline
#3 Old 03-27-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
19"x9" wheels in the front with 265 tires might be stretching what is possible in the wheel-well.
Durkatlon is offline
#4 Old 03-27-2014
curro101's Avatar
Quoted: 528 Post(s)
For the tyre sizes 265 & 285 :
If the figures I've put are right the fronts would be 12-17mm closer to the struts.
And the rear 6-11mm further in ...
curro101 is offline
#5 Old 04-05-2014
jameslk55's Avatar
Quoted: 17 Post(s)
So the problem with the front wheel fitment-does it mean it's too close to the struts and already sticking out past the fender?
Will CLK 209 wheels fit on SLK? TJer Tires, Wheels, Brakes & Suspension 7 10-20-2009 01:09 PM
SL AMG Wheels vs. SLK 55 Wheels MaKEuhigh AMGs 7 05-21-2009 07:19 PM
Set of 18 inch AMG wheels for sale, UK will777888 SLK Parts For Sale 3 01-01-2009 06:39 AM
Price help for New Wheels and tires shahedC Where to get R171 SLK Items 12 05-23-2008 10:57 AM
