Does it affect handling/performance? - Mercedes Benz SLK Forum
  • 1 Post By Durkatlon
  • 1 Post By lilred320SLK
#1 Old 02-05-2014
Vehicle: 2011 SL 550 Silver
Other Toys: 1982 Corvette, 2011 SL 550, 2014 MB E350
Send a message via AIM to NVelez9247 Send a message via MSN to NVelez9247 Send a message via Yahoo to NVelez9247
Out of financial necessity, I need to mount 17" wheels on the rear of my 07 SLK 280 while still running 16" wheels on the front. I will replace the fronts as soon as the rest of the funds are available. Will performance and handling be adversely affected by this?
NVelez9247 is offline
#2 Old 02-05-2014
aka John
Chats: 1143
Quoted: 30 Post(s)
I think you are going to get into a bind with the ESP, as it's going to be seeing different front/back rotational speeds - I had that happen with new 17's on the back and really worn ones on the front, so I suspect the 16/17 is going to be worse...
UK-C200 is offline
#3 Old 02-05-2014
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
Should be OK if the outer diameter of wheel+tire on front and back are within 3% of each other. Any larger and it's going to throw off various systems as John mentioned.
Der Flieger likes this.
Durkatlon is online now
#4 Old 02-05-2014
I'll vote with Durk. It's the tire OD that matters most. (170) Stock 16" 205 = 24.88 16" 225 = 24.86 (.08% difference (nominal calculated))
So Rim Dia, - Section Width, SW%, Calculated Dia. - % Difference
F-16 205 55 24.88 0.08%
R-16 225 50 24.86
F-17 225 45 24.97 1.02%
R-17 245 40 24.72
Can do this with simple math for any tire size. (Actual tire dia. will vary due to inflation pressure, mounted rim width, etc.. Which is why it would be good to stay well within the ranges. I like less than 1% difference myself.)
So if you use stock sizes, 16" front, 17" rear = .64% difference, you should be good.
OffLineR likes this.
lilred320SLK is offline
#5 Old 02-06-2014
Air Suspension Manager
OffLineR's Avatar
Vehicle: 2010 Grand Edition SLK200 Kompressor
Other Toys: AirMadZ - Air Suspension, Audi A4 Cabrio, GOLF IV Highline
Quoted: 62 Post(s)
Or you can compare with this:
http://www.voxwheels.com/
  • AirMadZ Air Suspension
  • Accuair eLevel Suspension Management
  • 19" OZ Superleggera IIIs
  • Michelin Pilot Super Sport
  • Wheel Setup Front: 225x35x19 - 8,5J - ET30
  • Wheel Setup Rear: 245x30x19 - 9,5J - ET20
  • SLK350 Brake Upgrade
  • Smarttop
OffLineR is offline
#6 Old 02-06-2014
To all of you that replied: THANK YOU, THANK YOU, THANK YOU!!! This is indeed the best forum ever, and it is a result of individuals just like yourselves. I shall wait out the rest of the month and change all 4 at once. Thank you once again.
Drag link questions. Does it affect alignment?! JaysonM SLK R170 General Discussion 32 01-20-2013 02:42 PM
A Sl with Wow Affect Berliner Heckflosse Off Topic 4 10-29-2011 05:52 PM
EPA approves 15% ethanol - How will this affect our engines? jbanks15 General Discussion 19 01-10-2011 03:09 PM
