1 - 11 of 11 Posts
what is this for? my door doesn't lock from my keys but i know its not battery problem cause the lights still flash
a search should reveal that the pump handles many functions.
This PSE pump support the air for your door(soft close), trunk(close & open) and your Dynamnic seat, Lumbar support &Massage,side bolster adjustment.
SLKWorld User # 10,000
take a look at your PSE first and make sure that its damaged and that your fuse didnt blow like mine did. If if checks out that your pump is broken go ahead and get my spare one.
I have a 2001 SLK320 .. same pump? I think I may need one, or some sensors. Still debugging. Had some false alarms tonite, open drivers door doesn't trigger alarm but pass door does. Also the interior light won't turn off unless I turn it off. Could be the driver's door sensor, just not sure how to test that yet. The central lock swicth on the dash doesn't seem to do anything either.
go and find your pump in the rear passenger side of the trunk and look at it. if the part number matches and you have water damage its done.
1 - 11 of 11 Posts
