Okay here is an update I think I have 100% found my issue but fixing it maybe another story
I have checked rear sam unit all seems fine from what I can see
I also checkes the fuse box near the steering wheel all seems okay there
So before I started removing the carpet to check the audio gateway and can bus, I went back to the front engine bay SAM just to double check all fuses all did seem okay apart from one of the last ones I checked wich is fuse 47 i believe its is linked to the cigarette lighter and ashtray illumination, interior sockets, and radio systems.
And it kinda confused me as I took the fuse out and fuse seemed okay so i double check it with meter all good but I popped a new fuse in anyway just in case but still reading nothing on my multi meter no battery voltage on DC on that fuse only all other fuses in SAM reading fine, then I switched it to OMs and once again that is the only fuse with an issue.
So i think i can safely say i have probably found the culprit but how do i sort it lol :L
