The wiper fluid sprayer has come disconnected from the hose on the passenger side on my 2002 SLK320. I've taken off the black panel, and can see that there is a plastic "T" that the spray connects to. It doesn't appear to be broken or cracked from what I can see. But, the sprayer pops out of the "T" with the slightest amount of pressure from the wiper fluid.
Has anyone had this happen? Can I just replace the "T"? Any suggestions are appreciated.
Mahalo!
Plastic tubing will swell/harden with heat and age so that it does not fit tightly on T. You could use a tiny clamp on the hose/T or you can buy T's the right size at a very good hardware store or Home Depot. An alternative if you have some slack with the tubing you can try cutting off 1/2 inch or so which will give you fresh bond. There is also a little marine epoxy (hardware store) on the T/hose joint. Lots of ways to skin this cat.....
Premium Member 2006 SLK350
Agree with the above..could try a small bundle tie but a small hose (screw) clamp would be best. May be time to replace the hoses, if this one has slipped it's brothers may follow shortly...any sign of cracking from age?
