1 - 8 of 8 Posts
2001 SLK230
I can't find the answer to this anywhere, hoping someone knows. whenever I turn on the windshield wipers, there is an extremely strong stench that happens. it seems to come right through the vent. like rotten meat in a hot garbage can smell. the wipers move/fluid comes out fine. the pump sounds normal. any ideas? is it possible anitfreeze is being burned/mixed into the lines?
Founding Member 2006
May I suggest that you drain off the "stagnant" water in the fluid reservoir and refil it witha good IPA (Isopropylalcohol) based screen wash. The IPA is a known disinfectant and the smell will not return. IPA is often inpregnated into swabs prior to needle injections.
It’s quite common for the additives in screen wash to separate out and form a gel in the reservoir. I don’t know what this is made of but I have seen green algae growing on it.
This can be cleaned out with hot water and your favourite detergent. Add a drop of concentrated floral disinfectant (Zoflora in the UK) and refill with clean water and screen wash.
Alternatively, your MB dealer will clean it up and refill with genuine MB screen wash and genuine MB water!
Neil
**Registered 2009 SLK200K - From Kent, UK
Neil
Or use a quality hose pipe
Quality water
Quality Detergent
And bill yourself a quality Mercedes Bill plus vat ! :grin:
Its so common windscreen washer / water to go off think about it it sits in there for years at times .
Ive had mine sitting in its resevoir bottle for 5 years plus
Yes i dont use it !
2002 SLK200K
I was puzzled by the "washer fluid smell", but if you don't actually USE the washer fluid and never drive the car below freezing, it¨s eminently possible for water to rot and smell lika rotten eggs. I'ts not the water that stinks, , the smell comes from anaerobic bacteria in the water. Most likely, they feed on algae from the tank and lines.
Remedy, use the washer now and then, or keep the tank dry, or use washer fluid additives of the correct kind. Isopropyl alcohol works well in my place (Cold, freezing, have road dirt cleansing properties etc). Chlorinated water (drinking water) also helps in this respect.
1 - 8 of 8 Posts
