Hello ,
when i closing the driver window glass up. It become over border from the top. It seems their is a stopper attach steel was been remove from the glue to glass. What glue are strong to hold the glass?:Beer:
Sadly Woolly has passed away
Hi Ramon, the best glue for this application is Loctite 349 Impruv, which should be readily available in the Philippines at any good engineering supplies stockist. You do, however, need a UV (ultra violet) light to activate it.
Ramon,
Moderator/Founding Member
