Hey everyone. I'm thinking of replacing the 16" wheels with 18" AMG OEM replicas I found and like on eBay. Will these fit on my car as is or do I need spacers, etc?
Condition:
New
Rim Material:
Alloy
Number of Bolts:
5
Rim Width:
8.5 and 9.5
Bolt Pattern:
5x112
Rim Diameter:
18
Hub Bore:
66.6
Offset:
32 f /35 r
Manufacturer Part Number:
MB512-18s-5112-3235S
Thanks!
SLK wheel chart
Thanks. This might be a dumb question but the chart you sent only has front in 30 offset. Can I put these on with an offset of 32? The back on the chart match up just fine as is
Registered 2004 SLK 200K
I can't see a 2mm difference being a problem ...
Registered 2008 SLK350
I don't think it will be a problem either but if you want to be absolutely sure stick to the official MB recommendations. See attached pdf.
BTW, in case your German is a little bit rusty, VA means Vorder Achse or Front Axle and HA means Hinter Achse or Rear Axle.
As you can see they only support up to 7,5 J front. Maybe someone else has some experience with a wider rim than 7,5 J up front?
https://www.mercedes-benz.de/content/germany/mpc/mpc_germany_website/de/home_mpc/passengercars/home/servicesandaccessories/genuine_partsandaccessories/tyres_and_wheels/tires_and_rim.0004.html
