Registered 2009 SLK350
Hi. I'm looking for some snow tires and a friend has some that are 225/50/17. Can anyone tell me if these would be too big? 2009 SLK 350.
Registered 2008 SLK350
To big in what way? Recommended is 225/45/17 so the circumference and diameter will be more (2066 vs 1991 mm and 658 vs 634 mm), meaning that your speedometer will be 3-4 % off. Your actual speed will be a little bit higher than what the speedo shows. But they will fit in the wheelwell, can't imagine these extra few mm's will be a problem.
As for width in winter conditions they are perfect. FYI, I ran with snow tires 225/40/18 fronts and 255/35/18 rears. No problem.
Thanks, S.P. It's all about rubbing
Hi S.P. I'm not concerned about the speedo error and my mechanic isn't concerned about any other effects, its just whether there would be rubbing during turns or bounces.
Will they be fitted on a new set of rims? And if they will be what is the size of these rims (width and ET) and are the OEM? If they are OEM what partnr. or from which model? If they go on your current rims I can't see any problem.
