1 - 2 of 2 Posts
as above which size replacement front rotors and pads fit a 2005 350 as there seem to be more than one size on brake sites
Registered 2006 SLK280
Do you have your datacard? That will tell you if you have the Sport package suspension, which had different brakes from the standard model, I believe. In any case, a good supplier will be able to cross-reference your VIN to select the correct parts.
1 - 2 of 2 Posts
