Where is the cabin filter?
2 reading
7.1K views 17 replies 9 participants last post by  jbanks15
#1 · (Edited by Moderator)
I have found a cabin filter off ebay.de here
Does anyone know where is the filter in our cars? Is it in the boot area inside the engine?
I have read that it is inside the cabin but i have yet to locate it.
Has anyone managed to change it? It there a procedure somewhere?
G
#6 ·
I'd have to check for a 170 but i believe its in a similar location as the 171.
So 171 on the passenger side remove the under dash trim once its out you will see the airbox (its big and white), it has a flat bottomed section that shaped roughly like a triangle.
It has 2 cream colored clips on it, slide them out of the way and the cover will drop down on that one side then you can pull it towards you and it will pop right out, the filter will also want to drop out so you really need about 8 hands for it.
When you put it back together make sure the alignment is perfect otherwise you will get cold air rushing out, sometimes this is unavoidable and we use a thin piece of rubber with the consistency of a door seal and put it either on the flap or on the airbox this then seals the gap when the flap is closed.
#7 ·
DansSLK:
From your description, it sounds as though the cabin air filter is a real bear to remove and replace. And I must note that my local MB dealer charges handsomely to do so!
What would happen if one were to have the darned thing removed, and just not replace it -- to not have one. Old guys like me drove cars for decades without them, and seem to have suffered no ill effects. Why is a cabin air filter needed?
Save
G
#8 ·
It just helps to clean the air that enters the cabin, removes some of the nasties that sort of thing.
If you run without it i can't see any big with that apart from the fact that it would be feeding dirtier air into the car, you do risk solid particles that get accelerated by the blower and are normally caught by the filter hitting one of the thin flappers that control the airflow and damaging it but its not like the A/C is going to be throwing rocks at you because the intake is protected.
The filter also removes the junk that we breathe out when the car is in recirc mode but again its not going to do any harm without it being there.
#9 ·
Ok i removed the passenger compartment (under the glove box) and I must say that i still don't know where it is. There is a big white plastic box. Am i supposed to open it?
Are there any pics whatsoever anywhere on the net?
Thanks for the replies so far
G
#12 ·
OK disconnect the electrical connector going into the airbox and try and push the harness up behind the glovebox so it wont get in the way.
Then move those 2 cream colored slides out of the way (they just push over) and that triangular section with all the ribs will swing down and drop off and the filter will fall out at you.
#13 ·
Are these the cream colored clips that slide off to the side? (red arrows)
Reactions: Jon Laurie
Save
