Hi just got these and am hoping they will fit ok my slk 2001 170 they are AMG off E Class but the offset etc seem the same?
Mercedes 18 inch alloy wheels
Offset ET35
5 x 112
8J
Thank you,
Moderator/Founding Member
They will fit, yes. But you probably won't like the way they look. The SLK uses a staggered setup. Rear wheels are wider than the fronts.
The wheels you listed will look pretty good in front, but will look too skinny and tuck under the rear fenders too much.
