Hi everybody, Since I only use my C200 -07 in the wintertime I'm thinking of putting the summerwheels on my Slk 280 -06 ( R171).
Will it fit?
Data for the two
C 200 Slk280
14x1,50B 12x1,50B
47 37
5x112 5x112
66,6 66,6
Regards Sds2490
Will it fit?
Data for the two
C 200 Slk280
14x1,50B 12x1,50B
47 37
5x112 5x112
66,6 66,6
Regards Sds2490
This would need some clarification.
66,6,and 5x112 is clear.
47 and 37 is probably the offset. 47 seems a bit to high for a SLK to me.
But what the hell is 14x1,50B and 12x1,50B??????
I know sizes of ie 18x7.5 for a rim, 18 inch in diameter and 7,5 inch wide.
But I have absolutely no clue what you mean with 14x1,50B and 12x1,50B.
Surely not 12 and 14 inch rims???????????
Thread size of the bolts ..
for the difference in bolt thread size I wouldn't try it , the offset is way off as well .
Ah, yes ofcourse.
Well, you can't use your bolts from the SLK then, the head won't fit proper in the seating of the rim. You will need bolts with a M12 thread and the head of a M14 bolt. Available here: spurverbreiterung - nach Gewinde&
But as Curro said the offset is also way off.
