Can I fit a mag wheel from an s class it is 18x8.5 44 et
Will these fit on my 2007 slk 280 if so what size tires would work
You will also need 10mm spacers for the rear and 12 for the front as the offset is way off, make sure to get hubcentric ones. Easiest fitment is 225/40/18 fronts and 255/35/18 rears.
