Don - Founding Member #4
:)Ad states they're actual MB wheels. Based on width, bolt pattern, and offset, they should fit OK. No need for new lug bolts or spacers.
Thanks guys,
If I put the OEM tire size for the 55 on them, will the outer circumference be the same as my 16"??????? Or will I have to have some programming changed to correct the speedometer??
:)Try this. Go to tirerack.com and check tires. It will give you a table with all specifications, check under specs, it will give you tire diameter size for different size tires. That will help you make a good choice, especially if you want to maintain the same diameter.
