Am I correct in saying that this the right size of bolts for my 2011 r172 slk
Mercedes Alloy wheel bolts M14 x 1.5 27mm thread 17mm Hex
If not can someone correct me
Super Moderator 2006 SLK 280
I'm confused about the bolt total length ?
Registered 2014 SLK250
Yep - definitely NOT cone for OEM rims. Cones are for [usually] cheaper aftermarket rims.
This is where the shout of 'search' is useless if all it does is bring up rubbish. Much better is to 'ask' which is suggested in other more technical forums.
You are correct first time, but add in 14mmR ball seat.
Thank you all for your comments
