Since I have the wheel hubs off while working on the brakes/suspension is it worth replacing the bearings? They are all fine no play or noise but should I do it anyway? No idea what normal 'life expectancy' is on car wheel bearings?
If it aint broke dont fix it !
You could then go the route shall i replace the front wishbone , the coil spring , the brake hose pipe the list could go on and on ........
You could change the bearing and then find the o/s rear coil spring brakes Friday .
Change what is worn or problematic first .
Leave 'em alone.
They will last 200000 at least provided they are not abused, ( launching boats, fording streams, poor greasing etc )
