Okay, so I've got a little cash...well, that's really pretty much all the time...LITTLE cash. Anyway, I've been researching performance mod's on this and other forums and I'm formulating a long range plan for various mods....
  • Cold Air Intake
  • SC Pulley upgrade and tune
  • Crank pulley and related idler/tensioners
  • Isolate/upgrade SC cooler system
  • Drop a biturbo v12 in it ;)
What is the groups consensus on which one to do first? I'd of course like the most bang for the buck. I'm thinking CAI simply because it's fairly cheap, adds a few ponies and makes the engine sound meaner (yeah, I know, sound isn't a performance issue, but sometimes you just gotta sing!)
Krazy (320Dreamer) will be the one to ask as he has done most of them.
I would definitely suggest the NeedsWings Dual CAI as it increase HP by a substantial amount (dyno'd). That's honestly all I have done and I have been happy. If I upgrade anything else, I would get the Supercooler.
cai, pulley (either sc or crank both need the needswings psk), ecu tune are first three!
after that: catch can, separated cooling, new ic pump, ported & coated intake manifolds/y pipe, lsd. Still much more after that too.
only limit is cash :)
bruco1,
Please update your location in your profile as it helps the members answer your questions which usually are based on that information.
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’. And it only takes about 30 seconds to do!
Thank you,
Moderator/Founding Member
Depends what you want???
V.nks as a student(which he still is)won car of the month with fab mods & on a budget. His car is beautiful. So, Horse power or looks? you did say' other Mods'
HP, I cant advise. If its looks, then slk world is am Emporium of information & endless opportunities.
If the Budgets tight, then feel great in the car you drive; rather than be faster in the car your never quite happy with. :tazz:
Pulley + ECU. That is your biggest bang for buck. CAI is minor or nothing according to Renntech. Next would be cams...
I will disagree on CAI being worthless. Rob @ Needswings has dyno AND 1/4 mile slips with just a CAI and it is a remarkable difference. Then again if it is a poor CAI design that would explain Renntech's thoughts...
