1 - 13 of 13 Posts
Car was in for service 2 days ago. Got it back and CPS seems to have failed. After pulling off the plastic engine cover / air box, I noticed this laying on the radiator support near the main hood latch. I didn't hear anything drop and it doesn't seem to belong to any part of the air box.
Anyone have any ideas what this is? It's a metal rod inserted <1 inch into a rubber tube. The far ends are each cut square so it doesn't look broken but the rubber tube where the rod is inserted is not cut even. Is this a makeshift tool the dealer used for some purpose and can be thrown away?
Thanks in advance.
Until you get a reply
I would have went straight back to the dealer and asked them
maybe get something 'free' for your trouble
i once came back from the dealer service and had a big wrench sitting on my windshield cowling
Yikes! That's like mechanic 101 - never set down tools around the engine bay (at least that's what I was taught). Pssh... nothing free from my dealer. I will drop by Monday and ask anyway. Also discuss the coincidental fail to start issue after they had their paws on it. (The area by the CPS doesn't look recently touched but it doesn't leave a good feeling when stuff breaks 20 miles out the service bay when everything was fine before it went in.)
I searched EPC (Electronic Parts Catalog) for your 'part' with no luck
i searched the CPS area and the radiator and engine cover areas
Registered 2009 SLK200
That looks like a vacuum rubber hose pipe with poss a brake pipe inserted inside .
A tool temp made by fitter to test diaghrams or by pass items etc
And left behind .......
Agree. It looks like a vacuum line that someone either blocked on purpose and it fell off, or that the tech used to test a vacuum point and left on the engine. Look around for a vacuum "nipple" on a component nearby, or another vacuum line that is unattached, and that should point you in the right direction.
Was the wrench a good looking lass ?
I would of not returned her and kept her ;)
>:D
wrench! not wench, you pirate!
what code did you get when CPS failed if any?
1 - 13 of 13 Posts
