and for others:Having joined and already benefited from other members advice I had a crack at changing the Cabin Filter.
20 min job according to youtube. not exactly! but by my standards less than an hour is good including 10 minutes trying to find the second yellow clip which was nicely nestled behind a wiring loom!
The main horror was the amount of large crud sitting in the old filter, never mind that it looked like it had been in since Adam was a lad.
So cleaned out, new filter fitted and then decided to make a coarse filter to go over the massive air inlet for the cabin fan.
This is what I came up with. All Aluminium, held in place with magnets. Not perfect but should keep all the large stuff out. Shouldn't affect air flow (not like the crud in the filter did).
Didn't realise that scuttle came in so much towards the A pillar! so that's a mod to do! and perhaps some insulating tape to it doesn't chafe that very expensive looking drain hose.
Thoughts?
Had cabin heater out a few months back, surprisingly clean. Especially as we park near trees.Having joined and already benefited from other members advice I had a crack at changing the Cabin Filter.
And minty fresh! 🙃Cleaned the head light lenses with tooth paste worked very well.
I fail to understand why you are promoting bulbs which are prone to bending with use? If that had fell to bits inside the light you’d have some fun taking it out! 🤔Passenger side LED Parking light was flashing....so had to change it
Fortunately it was the passenger side and not the drivers side
Driver's side I have to go through wheel well as Super Charger stuff in way from the top.
So passenger side was a breeze
Old (it was bent so I finished the job before removing with needle nose)
New in and link to ijdmtoys where I get it 10-036 is part number
Daylight out so tough to see
installed
Hi Petri, did you use the cable taps that came with it or solder in the leads? Was it difficult? I plan on fitting one for the spring time.I installed a S/T today just for fun, and it works great.
Now some better lights in the trunk and inside the car.... and wait for the snow to go away.
Those cable taps that are provided should have been banned in the 1990´s ..Hi Petri, did you use the cable taps that came with it or solder in the leads? Was it difficult? I plan on fitting one for the spring time.
Thanks for that. Would you mind posting a photo of the fuse box with all the extra cables installed? I'm interested in how tight it is in there with added wiring. ThanksThose cable taps that are provided should have been banned in the 1990´s ..
Don´t use them..... But that´s my opinion.
I cut the cables and used duraseal joints.
like these ones.
The one I´m using is first pressed and then heated up.
They are filled with glue and shrink to get a watertight connection.
I don´t do it the easy way so it took me about 1 hour.
I also protected the cable from the fusebox to the CCM with a cover.
Here is the rest.View attachment 591290
Under the fuses you will find these 4 connecting points.
Those 3 that I have marked is what you need to work with.
Step 1 is to identify the single Pink/Red wire under #2, it´s connected to fuse #7
Move that to connection #3.
Then you take the relay that comes with the S/T and place the red wire on #1 and the Pink wire on #3
Put the fuse holder back and place the relay somewhere suitable.
I placed it in a empty space in the back. (Red marking)
The green marking is where I got the black cable going over to the CCM.
The black wire is just a 0,75mm² and the protective "sock" I use is not included.
I can get you some pictures from the CCM side later today if you want that.
Have a great day and stay safe.
