Hi to everyone.
I thought I would have a scour through this forum to see if anyone has had a similar problem. Also, if it saves someone else having a similar experience it is worth the post.
I am in the UK and have a 2005 SLK200 although I suspect this problem may not be restricted to SLKs.
I have had the car from new and up until now have had no problems.
It has been serviced by Mercedes since new.
About 3 weeks ago the air con blower (heater fan) stopped working. A quick trip to the Merc dealer found no obvious fault and they suggested the blower would need replacement - approx cost 250UKP.
This week I booked the car in for the work. Mercedes then ring up to inform me that water has leaked through the bulkhead into the car due to a drain hole in the battery chamber becoming blocked.
So, as well as the water taking out the blower motor, they need to replace battery, alarm siren unit, take out all carpets from passenger side and dry out the car.
Cost ÂŁ1400 UKP
I immediately argued against this and they have reduced the cost by 50% but will not budge any further (so far).
I am angry because this could easily have been avoided. It seems reasonable for Mercedes to check for these sort of problems when the car is serviced. If I had known there was a potential problem I could have done a regular check myself. I'm not sure yet what my next course of action will be but I suspect it's going to take a lot of correspondence before I achieve anymore than what's been offered.
Mercedes won't even just sell me the parts at the discount, they have to fit them for me to qualify for the "goodwill"!
I may source the parts myself, get the car fixed and pursue compensation separately (I need a working heater!). Could anyone point me somewhere where I can source the part numbers from?
In the meantime check your drain holes!
Regards - Ian
Cost ÂŁ1400 UKP
Regards - Ian
