The water drains on the R170 become blocked with leaf litter etc. One bad thing from this is water ingress into the boot and then into the PSE unit. :mad:
Tey need to be cleaned from time to time, I use a length of 1/4" tube and an aircompressor.
http://www.benzworld.org/forums/r170-slk-class/1300402-rear-drain-problem.html
To help reduce the problem I have put stainless flywire over front and inside rear drain cover.
http://www.benzworld.org/forums/r170-slk-class/1301756-drains-front-rear.html
Crud can then be hosed off when washing the car (if only we were allowed to do that down under ATM :td: )
Bazzle
