Registered 2012 SLK350
This post lists items to check/configure to use a C3 (Called PartD) with Vediamo. Note that the last version to support PartD is 4.02.02.
1. Check that the COM port your C3 is connected to is the one Vediamo is looking to use:
Go to folder "...\Vediamo\Caesar\driver"
Open slave.ini, search for [PartD] and check that it matches the COM port you are using:
"Com=2 ; COM port"
2. In the Vediamo ini editor (Yellow notepad with pencil) check the following items:
Hardware -> Use PartD -> Check USE_SISerialDriver
And if I remember correctly that is it!
