1 - 20 of 22 Posts
Hello.
This afternoon I lower the vario roof smoothly and went for a walk. All is ok.
But to reach my destination, press the button to raise the roof, but the roof does not rise. either the trunk is opened. Nothing happens, no noises pump..nothing.
Lcd show: Vist workshop.
The battery and fuses 21, 37 y 38 are ok.
Can you help me?
so you were using the inside button to raise/lower the roof or the keyfob?
was engine on I assume?
so the trunk did not open?
and no message on display like trunk partition open?
can you open trunk with key? to check and make sure roller is still in position
did you check the roller? is it still in its holders?
when the roof is up and you get in the trunk, there is the cloth roller that you can roll and unroll to put things in the trunk
when you want to put the top up, the roller is rolled out and secured in position. then after closing the trunk, you can open the roof. maybe the roller came loose from where it is extended in the trunk
the roof cannot go up or down if the roller is not properly in place (extended, not rolled up)
My bad. you guys are correct. I even sent him the R171 troubleshooting tree! :D
1 - 20 of 22 Posts
