This is my first post, and I'm hoping someone can shed light on my problem. I have a newly purchased R171 2011 SLK300. For several weeks the Vario roof has been raising and lowering as it should. Today I tried raising it, and all appeared normal until the trunk lid lowered. Then the motor sound continued longer than normal, and then stopped. Neither the front nor vent windows ever raised. The trunk cannot be opened (although it can if I put the top back down, which appears to work ok). And the dash indicated that roof raising was in progress. The main windows can be raised and lowered with the window switches. My Icarsoft i980 scanner yielded code 9923: "S69/3(Vario roof "locked" limit switch (right rotary tumbler): The component does not operate or has a cable break" Thanks.
