1 - 13 of 13 Posts
i know its a bit much PLEASE can any one take photos or his/her working car air vacuum lines ??? like the ones underneath the front engine cover going in to the s/c i found only one guy who took the time and took some pics but they where blurry as heck and only for the s/c not going to the throttle body and stuff . THANKS !!! i have the new lines ready to be cut ^^ the damn car is running super lean QQY)
Premium Member 2002 SLK230K
If you can wait until tomorrow morning i will take a few, just keep in mind my car is a 2002 so the lines may be a little different.
thanks im going out to the scrab yeard now i need a pipe that has been broken it comes out from the side of the engine manifold side anyways thanks :>
you have of course checked Leapyfish's sig block for any help?
http://www.slkworld.com/447953-post5.html
im usre i have looked at it 3 months ago when i started looking for it :S but now that i have my s/c up and running i need the power :> but anyways i looked everywhere no body did show it or at least i couldnt find it .
It sound like one of those breather hose. It under the intake manifold and the hose is connected to a valve (I believe). I replaced it myself but required remove the intake manifold. I think I posted pictures on the other forum.
This is the best i can do without removing a bunch of parts, hope it helps.
THANK YOU OHHHHHHH SOOOO VERY MUCH Y) but the thing is your car is not like mind :> but im sure many will use those pic ^^ anyways i went to the scrab yard and i bought what i needed and i looked at the other engines and asked around the guy there told me what to do and im about 80% done now ^^ all the need is go to the mecha tomoroz and hook the new((used)) item and to it the air pipes ^^ photos are in bound ^^;)
Livefreeordie, just wondering from seeing Your pictures.
I´ve only got a hose as the green one the picture but You have a T-nipple which splits the vaccum-line into a red one also. Where does the "re-lined" vacuumhose go?
so i got around to do it yesterday and this is what i did! i think i did it wrong coz the car is slow yet ...
so what do you think ?? did i do a good job of re routing all the vac lines ?? if so why is it sooo corolla slow QQ
Were you able to confirm those connections?
I'm interested in the lines 2 and 3 that you circled in your picture.
These two lines broke off and I can't figure what goes where.
In the picture I have attached, I've connected line 3 to the shut off valve.
I was able to locate another 1999 slk230 and checked under the hood. The vacuum line connected to the top of the switch-over-valve(y32) goes to the shut-off-valve and the line that is connected to the left side of the Y32(facing y32), goes to the supercharger. I had mine reversed in the picture I posted in post #12
1 - 13 of 13 Posts
