1 - 2 of 2 Posts
I purchased the Baum Tool to attempt a job I had never done before...LCA bushing removal. Turns out they were original and in too tight to get out with the tool (It bent the bolt, but I purchased a brand new one to replace so I could sell the kit...$50 bolt!) I ended up just replacing the entire LCA's. I also have the Rein Bushing kits (AVB0339R) I did not use. Hopefully someone can get some use out of these and they will simply go to waste in my garage.
https://www.ebay.com/itm/323027304118?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
https://www.ebay.com/itm/323027316862?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
In no particular order
1 - 2 of 2 Posts
