The rear bumper on my wife's car was looking a little beat up, then I leaned against it and cracked it. I found a Sport model bumper in good shape at a junk yard, and did a swap, so now the original is available. It shows it's age a bit, as you can see in the pics. The third pic shows the crack I put in it. The fourth pic shows some scrapes and rubs along the top edge, at the trunk line. The fifth picture is a bit hard to see, but there are some scuffs along the face, which would probably buff out.
This would be a local pick up, or nearby meet up. I can't imagine it being economical to have it boxed up and shipped. But if you want to go that route, I will do it if you are paying for it. Currently in the Yorktown, VA area. I could get it up to the DC metro area in a month or two.
Note: I took the two antenna panels off this bumper to put on the "new" bumper. I have the antenna panels off that bumper, but no idea if they work properly. I would recommend transplanting what you have, but I have a set that I can include, if desired.
$100, as is
Contact info?
In no particular order
4. Seller, please post a reply informing us that it sold when someone buys it. Saves folks trawling for parts, only to find that they have gone. Thanks.
And now I should be able to receive PMs, too.
only after system updates/refreshes your status
when you see the 'edit' button at the bottom of your posts, then you can reply and send messages
