I will give away the old motor from the '99 SLK 230 Kompressor that I repaired these last two years. You have to come pick it up as I will not ship it.
The motor is supposed to have a cracked head from repeated overheating. I have not separated the two to verify that. This is only the block with the rotating assembly, head with the cams etc. still installed, intake manifold, fuel rail with old injectors, nothing else.
Again, it is free but you have to come here and pick it up.
I live near Lafayette, TN.
PM me for the address and phone number if you are interested in this.
Super Moderator
FYI and Suggestions for the For Sale section
In no particular order
Note-This item is free. Read the description and the requirement to collect.
Members with less than 15 posts cannot PM seller.
Either welcome 15 new members
or leave a reply here and @dedgar can PM you.
It has been almost two months now and no one has inquired about the engine. I'm not going to keep this in my garage waiting for someone to decide they need it. So off to the metal recycing it goes.
Will an admin please close this thread.
Thread closed
