1 - 10 of 10 Posts
Datacard also attached
Registered 2002 SLK320
I actually just posted the same question, but I have a 2002 so the part numbers are slightly different. I have found 3 of them, but not the 4th. They seem to be out of production almost everywhere. If you find a source or a repair method, please be sure to post your findings. I do most of my own repair work, so I need to use the jack occasionally to remove the tires for brakes, shocks, etc. These covers seem to get brittle over time and the tabs break off. I'm currently using a thin double-sided tape to keep some of mine in place. Some type of repair using magnets to keep the covers in place would probably be ideal. Please post your part numbers so the members can do some searching for you.
Best of luck to you!
Jack Hole Cover
I just had some work done and the body shop said they would order it. When I picked up the car they told me jack hole covers were no longer available. I got one off Ebay. They want a lot of money for a little piece of plastic but there doesn't seem to be any other way.
1 - 10 of 10 Posts
