Undershield Metal vs. Plastic
2449 Views 11 Replies 8 Participants Last post by  markja
Hi everyone! I was planning to remove my undershield (A170 524 03 01) for some weight reduction (13.3 kgs) but I noticed that also plastic versions are available. On WIS there is a part listed (A170 524 08 30) which is only 1.3 kgs and it is around 40€.
Can anybody confirm this is the same part that I can exchange with my metal shield? (I have a FL 200K)
I don't need the shield. And together with the spare wheel and other stuff in the trunk it makes big saving in total. I need the panelling just to keep the cats off the engine bay. 0:)
1 - 12 of 12 Posts
The engine is the most expensive part of your car. I would definitely NOT remove the metal protective cover, and replace it for a plastic one. If you wish to reduce weight, go on a diet, or refuse to take a passenger. Not meant to offend you; only meant as a sincere advice.
Arjen.
Reactions: 4
I agree, the alternator is a sitting duck without a belly pan.
The shield is also used to cut wind temperance going down the road as well water splash. Do not think you are doing off-road in an SLK therefore a plastic would work as well as a metal. Either way one should be used.
They wouldn't make a plastic one if it didn't work! Metal ones rot like ****, that's why they went to plastic :wink:
Not to highjack this post, but does anyone know where to pick up one of these shields for less than the dealership? My car didn't have one when I bought it and I've looked and looked for one for a decent price with no luck.
They might have gone to plastic to be cheaper. Lots of stuff out there doesn't work; just because it is made doesn't mean it should be used. Not saying it applies here but...
Someone on here made one out of a wheelie bin, i assume he used metal one as the template?
The metal protectors have been made of galvanised steel. I would not worry about them rusting, because (1.) it is fairly simple to replace them, and (2.) by the time these plates start to rust, I would rather worry about rust on the painted body parts of the SLK.
The reason for using a plastic shield as the default factory setup cannot have ben the avoidance of rust; if that were the case then the R170 should have had a fiber glass body or a better rust protection in general. More likely, the choice for a plastic engine protection shield was driven by the desire to save both costs and weight (helping to improve the fuel economy somewhat and the weight/road tax classifications for some countries).
For most roads the plastic shield will probably do fine, but since the TS asked for opinions, I shared mine.
It has been many years since I have driven in Turkey (where the TS resides) and at the time the roads would definitely have justified a metal engine cover. I took that into account when giving my opinion.
On our Dutch roads, potholes in and large stones on the roads are rare, but we have plenty of nasty speed bumps. When I purchased my R171, I asked the dealership to install a metal protective cover underneath my R171's engine (replacing the default plastic one). My risk aversion was driven by the fact that cracking the engine means totalling the car. If the TS is willing to take the risk, then I would say: Go ahead. Again, however, I would opt for other measures to improve the fuel economy.
The total weight of the R170 SLK200 is about 1,300kgs; for me the limited percentage of weight reduction (you take out about 13kgs, equalling 1% of the total weigth) simply does not offset the dramatically increased risk of totalling the car. Would there be a 1:1 relationship between weight en fuel economy, it means you may drop from e.g. 9L/100km to 8.91L/100km. I find that negligible. Always driving around with less than half a tank of fuel has a bigger impact (18 litres of petrol also weigh approx. 13 kgs.). Alternatively, look for tyres that are more fuel economic (if you are willing to accept the increase in noise), or adjust your driving behaviour.
Arjen.
See less See more
Reactions: 1
Dunno about galvanised, but my 99 plate one certainly wasn't. It looked like swiss cheese & was only good for scrap, deffo not protection!
I had to Google what a wheelie bin was :grin:
Reactions: 1
that was me!!!
and yes i used my old, rusted out one as a template.
under the car so not visible.
weighs about 1 & 1/2 kg. instead of the ton or so for the metal one.
i didn't know you can buy plastic ones, would have saved me a load of time.
1 - 12 of 12 Posts
