Sort of, but you've not thought how the car thinks and what it needs to see to shut down properly.
Whoever is doing this job needs to be fully conversant with how the Car works
For example lock the bonnet latch with bonnet up (R170 ) or put a cable tie / elastic band around the bonnet pin switch (that VXR Astra),...............
Also you may need to get in and outta the car for testing, so I leave whatever door(s) open but fasten their locks and clamp down any pin switches ....................
And then if you have a drain and need to start un coupling wires or pulling fuses, a lot of times the meter will spike up, then you have to wait before the next test to allow the Car back to sleep mode ..............................
This is why I charge what I charge by the hour, it can take all day ++++ in some cases to find a current drain ...................
There are ways to speed it up, but it is hellish to explain and I don't got time to go into all that, but very basically I split the car into sub sections, by removing main power from each and every fuse box one at a time so pull the power from each one of them one at a time and if drain goes that's the area to concentrate on
Wait until you get a car with several drains due to water ingress ................. 39 hours to fully sort one of 'em a while back, car was only worth twice that cost
