1 - 14 of 14 Posts
Premium Member 2004 SLK200K
Brain picking time again , guys & gals .
I'm trying to sort out a problem for a member on the national forum I'm on and need some advice from the r170 experts please .
The problem is the following :
When the indicator/turn signal is used , indifferent of which side , both sides indicators come on ( same as the hazard/emergency lights ) .
Any ideas would be appreciated !
bad bulb?....
Shouldn't be a bulb as they all work , just not how they should !
What do you mean by the multi function switch ?
on some model cars, when a bulb is bad, the signal will blink faster so I was just throwing that out for what it was worth. Apparently it was worth bubkis!
Is there a relay switch in the R170 that may be common to the indicator stalk/lever and the "hazards" switch? Just thinking that the indicator lever switch may be either be faulty or a faulty relay is sending the signal to all sides irregardless of the indicator control lever position.
Reactions: curro101
Oh , ok , you mean the indicator stalk , could be ..
I believe the indicator relay for the pre facelift r170's ( just found out it's a 98 ) is built into the ECU , N10-3 module ?
What's exactly the connection between the PSE pump and the indicators ?
I asked the owner if he'd checked it for corrosion and he NOW tells me , that he's just bought the car , never tried the indicators before and has no PSE pump what so ever !!!
Very probable culprit , right ?
1 - 14 of 14 Posts
