1 - 13 of 13 Posts
Registered 2005 SLK55 AMG
Hi guys , as per title I am ordering a set of replacement rotors from MTEC and they have asked me to double check the PCD and hole size of the rotor where it bolts onto the hub. I know the overall size is 340mm and it’s 32mm thick. But wondered if anyone knew these other dimensions. Thanks
Hi there Avel Du the link doesn’t seem to work on my iPhone , it doesn’t seem to drill down enough, but thanks anyway.
if on a phone
exit
enhanced mode and try again
phone menu top left
scroll down to exit enhanced mode
or get off that phone :D :D
Thanks have read it twice now but can’t see PCD of the 10 bolts that connect the rotor to the brake hub. I know there’s 10 bolts but wanted to know bolt diameter and PCD.
I think I might just have to take the wheel off and measure it.
Thanks just looked but I think it doesn’t give the 10 off bolts that holds the 2 pieces together PCD. From the others dims I would guess it’s 205-210 PCD , but a guess isn’t good enough.
A couple of other members have used MTEC.
They might have ended up sending MTEC parts to measure, not sure.
They may not be on today, but will likely check in by weekend.
Registered 2006 SLK55 AMG
I really can’t understand why MTEC don’t have these dimensions, they’ve made at least 2 sets of these before that people have reported on this site. It was their attitude which put me off dealing with them last year, just couldn’t get any confidence I’d get the right product.
Discussion Starter #13
Well I did them to make a set for me, by sending a rotor off. All fitted now but won’t be back on the road until April so can’t report on them as yet. They look good though
1 - 13 of 13 Posts
