1 - 9 of 9 Posts
Registered 2006 SLK55
I just bought a 2006 SLK55 w/100k miles and it has an issue. When I put it in drive or reverse, it waits a few seconds before it engages. Once it is in gear it seems fine other than downshifting pretty abruptly as I approach a stop (10mph), but I think that's common in these cars from what I've read. Has anyone had an issue like this and found a solution?
Founding Member 2006
When was transmission fluid checked/changed/drained last?
First please update your location and vehicle (year?: 1996-2016, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
*DAS/STAR Premium Member
2005 SLK55 AMG
Hi and welcome, and as the Master Sarge has pointed out, please update your details!! (it helps no end...)
I'd check first to see if the car has every has the transmission fluid changed.
Is this your first auto ..? I only ask as there is a small delay between moving the shift lever and drive engaging (not much though)
The rough downshift, especially into the lower gears can be a sign of the conductor plate problem, but they can also be rough when cold, especially if you start off in S and travel a short distance before it has to downshift to 1st
Sold my SLK
I replaced my conductor plate at 80,000 miles, but the symptoms were more that the car would not shift out of a gear after coming to a stop. Just stay in first until I turned the car off and back on and then everything was fine.
The transmission fluid is on a 40,000 mile interval, and there is a filter as well. You should also try changing the mode of the transmission to see if it changes anything. In Sport mode it will down shift to slow the car, but in Comfort mode is shouldn't and rides smoother.
As an expensive resort, you can go to a dealer and/or Merc qualified Indy and have then read the STAR codes. This will help you diagnose a conductor plate issue. If no issue then a transmission fluid and filter change ran me around $400. The conductor plate replacement was $1,200 but includes the fluid/filter change.
Best Wishes,
Discussion Starter · #6 ·
Great advice! I switched it from S to C and the jerky downshifting cleared up beautifully (and it's still plenty fast for me). Still has the 3-5 second delay in engaging when placed in gear, but I'll research the conductor plate now. Levels should be fine because I had a reputable mechanic do a complete tranny service on it when I swapped motors a week ago.
* Founding Member #2
2008 SLK55 AMG
Great advice! I switched it from S to C and the jerky downshifting cleared up beautifully (and it's still plenty fast for me). Still has the 3-5 second delay in engaging when placed in gear ....
Based on how my cars behave I would have to say that 3 to 5 second delay is indicative of a problem that needs fixing. Ignore at your own peril .... will end in tears! :crying:
1 - 9 of 9 Posts
