Hi Chaps,
Anyone know where to buy the screws used in the instrument cluster? I'm taking the centre console cubby out to put a cupholder in and there aren't any screws in there! I suspect they were lost when the previous owner installed a Bluetooth kit.
Thanks.
items 90? if so, part number in pdf attached. go to mb parts or order on any online site
Let me know how it works out. Those puppies are easy to lose. I actually tried to get some at my local Parts department after I kept dropping them into the abyss that is the center console taking mine apart. They couldn't seem to find them, and after three tries of "Nope that's not them" I gave up and bought some Phillips head screws at Lowes. You may want to try a specialty hardware store. as long as you match the thread and length you should be OK. I'm guessing that 4.8 x 22 means something. :)
Best Wishes
OK, cup holder in and perfect size screws found.
If you're in the UK pop into a Wilkinsons. They do a small bag of screws for £1.99. I filled it up with a selection of every screw they had in the hopes one would fit. The small, black plastic screw they do fits perfectly. If anyone needs it I can try and get the exact size next time I'm in a shop.
They hold the cupholder/console cubby perfectly.
