1 - 2 of 2 Posts
What are the correct torques for the following on a 1998 Mercedes Benz 230 SLK Kompressor: engine oil drain plug, engine oil filter, transmission oil drain plug, transmission torque converter drain plug, transmission pan mounting bolts; in other words all the torques necessary for an oil change and a transmission service? Thank y'all!:confused:
moving to the general discussion section
The DIY section is for already created DIYs only.
If your question pertains to a procedure in a DIY, please post the question in that thread.
Someone will respond if they can assist and answer your questions and
will point you to a DIY if one is already made.
1 - 2 of 2 Posts
