1 - 9 of 9 Posts
Premium Member 2010 SLK300
@peZonator
Where did you order it from, I might want to do this mod as well.
Sent from my LM-V405 using Tapatalk
Registered 2009 SLK350
All fitted and now just to wire it up
Star is bigger than original
I am happy now to see it lit up..
How were you able to fit it without removing the bumper or grill?
I will be attempting this so any tips would be appreciated.
tape up all the surrounding areas, cover grill bits with a rag , then get a die grinder and start cutting away
be patient and gentle
the lower part of the original housing goes up at a 30 degree angle, you need t take all of this out
i then kept making the hole bigger so that the star goes into place tightly
you will need to remove all tabs from the new housing and star so that it fits in
i have not wired it up as yet due to other commitments , but i will be heading to the fuse box in the engine bay and setting it up from there
good luck be patient and it will come up looking great
small tip..when fitting put a piece of masking tape on the bonnet above the star and work out the HIGH point is... mark it with a pen so that you may align your new star
good luck
be patient... it is worth it in the end
and the lines that appear on the emblem in my pic is the reflection from the fluro tubes
Thanks great info. Yours looks like it came from the factory. Great look.
Like your lights, I have those as well.
love the lights
thank you ace
buy yourself a tube of araldite so you can glue everything together ;)
1 - 9 of 9 Posts
