1 - 14 of 14 Posts
1998 SLK230K
Greetings to this Group! Hello... I was wondering if any or all of you could help me in my pursuit....
I am trying to get info on my families SLK... to prove the story with documentation of the Legend my father told me about how our SLK was one of the first 5 SLK's in North America.
My father ordered the car special order per sale in we believe 1996. There was a bunch of hoopla... they would send special thank you notes, and even a Key chain with the two SLK hood humps on it, which on the back reads " charter Member" ( I still have the key chain) In March of 1997 my father picked up car in California, I am not sure where. He drove it back home to Las Vegas were it was the only SLK in the state at the time early 1997... The DMV calls it a 1998 SLK
The car 230 Kompressor is classic silver with gray and black interior with carbon fiber center panel . it has the tri- spoke rims which I have only seen on one other SLK... It has no Radio antenna on the outside
The door tag says that it was made in Stuttgart ( not anywhere else, just Stuttgart) made 2/ 97 ... it has the lowest VINs I have ever found... WF013175
any advice on were to start to verify or deny this legend... thank you
-serf
Founding Member 2006
post vin
a vin has 17 digits
Here ya go!!
Early model R170s (1996-2000) have very little data in their datacards and some of the info might be erroneous like saying you have a 'DARK BLUE SOFT TOP FABRIC 5010' which we know is wrong
that says your car is a 1998....1st slks were 1996..........
built in 1997
Model Year1998
ModelSLK230
Engine111973 12 005763
Transmission722605 00 294296
Order Number0 8 705 22700
Order LocationUNITED STATES (USA)
InteriorLEATHER QUARTZ (225A)
Paint 1BRILLIANT SILVER METALLIC (744U)
Delivery Date1997-02-24
Approx. Build Date1997-02
1998 SLK230K
Discussion Starter · #9 ·
built in 1997
Model Year1998
ModelSLK230
Thank you for your time, experience and dedication to this site... Thank you
Do you know if Dealers were selling them in 1996 in the states, or where they just in Europe.... were there any code 461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND or code 494 U.S. VERSION sold in the US in 1996?
German cars appear first and sold first as you would imagine in Germany and Europe by about 6 months before they even appear in the USA. So if your car is a model year 1998, I seriously doubt it would have been among the first in USA.
Members with USA 1996 or 1997 R170 230s will chime in :D
does not look good...read below
The SLK was announced to the USA market on Sept. 7, 1997 as a 1998 model; it was available in Europe during 1997. The SLK's compact styling, retractable hardtop and optional 185/190 H.P. supercharged (Roots type) engine were a major departure from the large SLs of the previous quarter century.
The SLK was a modern incarnation of the 1950s 190SL by returning to four cylinders and a 94-inch wheelbase. Massively successful even its first year, worldwide sales hit 55,000, over double the entire nine-year production of 190SLs! The SLK was named “North American Car of the Year” by CAR & DRIVER magazine for 1998. Only in the USA sale of the SL320 (6 cylinder) was ended when the SLK arrived to distance it from the senior SL.
Chronology of Features and Changes
1997/1998: First year features included a five-speed automatic transmission, ASR to control wheel spin, ABS brakes and front and side impact airbags. The five speed automatic defers to higher shifting points when it senses “spirited” driving. It also changes shifting points when climbing or descending.
Three engine variants were offered:
1. normal
2. supercharged (kompressor) 2.0 liter and
3. the C230 sedan's 2.3 liter engine with a supercharged -- the later being the only engine for the USA and UK.
A supercharger was chosen over a turbo as peak torque begins sooner at 2,500 RPM, up to 4800. There is variable rate valve timing, electronically controlled oil pressure, antiknock (ping) control and an anti-theft engine disabler. The distributorless ignition features a dual firing coil for each cylinder. Rear axle ratio is 3.27:1.
In the summer of 1997 US production included cruise control, air conditioning, an adjustable steering column and brake-assist, which became standard for the UK also. A few early cars do not include these features. The rear window is glass w/defroster. 1998 also brought "Smart" to turn the passenger’s airbag off whenever light infants or a booster seat was belted in.
Larger tires are used at the rear of the supercharged model which increases neutral handling. 16” wheels were used from the beginning. Suspension design conformed to M-B proven wishbones in front and five-link at the rear. The exhaust system's center and rear mufflers are stainless steel. Headlights are halogen with variable focus reflectors. Remote key codes change every time the key is used however a transponder built into the key also exchanges a code in an electromagnetic coil that surrounds the ignition lock as an added antitheft control.
Fog lamps, power side mirrors and tinted glass are standard. Ditto power windows, cruise control, a telescoping aleather wrapped steering wheel plus climate control with dust/pollen filter and separate controls for driver and passenger. Initial weight of the 2.3 was just over 3,000 lbs. 0-60: 7.2 sec. Top speed: 140. EPA city/hwy: 22/30 In the USA there were only four options: heated seats, metallic paint, heated headlight washers and a choice of telephone/CD changer combinations. A four-year/50,000 mile warranty included tires and battery.
1999: The driver adaptive five-speed automatic transmission became a $900 option, and about 20% of the US customers were expected to select the five speed shift. M-B claimed identical performance for each. A new $3,990 AMG designed Sport Package included 17" wheels, and rakishly styled side sills plus front and rear fascias.
2000: Two unique "designo" paint and upholstery options were added. The "per Edition" came with copper metallic paint and an interior finished with copper and two-tone charcoal leather. Steering wheel, shift knob, floor mats, center console and rollover bars also receive a copper and charcoal. The 2nd designo SLK is "Electric Green," using charcoal leather and trim with light green. Other interior options are Oyster/Charcoal or Salsa/Charcoal combinations or a solid Charcoal version.
A stabilizer bar was added to the rear and they reinforced the front one. A 3.46:1 axle was added for the manual shift SLK. Gas tank grew from 12 to 14 gallons.
2001: A 3.2-liter V6 and a six-speed manual transmission arrived in 2000 as a 2001 model. Concurrently the unibody was reinforced and they thickened the sheet metal of the ellipsoid firewall. Impact absorbers were added to side members to support the wheels in an offset crash. Inner panels of the doors were reshaped and reinforced. A link between the rear side body and main structure was added to disperse rear impacts. Brakes were enlarged on the V6.
Tele Aid and EPS became standard for all Mercedes-Benz in the USA. Tele Air incorporates remote diagnosis, emergency door unlocking and theft alarm notification. Emergency and non-emergency buttons establish immediate voice contact with reception specialists who can dispatch local police or other services. GPS tracking pinpoints location automatically. This also tells authorities the location of stolen SLKs. The 3.46:1 axle was dropped in the USA.
2002: Enter the SLK32 AMG with a whopping 349 HP. (0-60 in 4.8 seconds) Three engine choices: 1) 192 HP four valve, supercharged 4 cylinder, 2) 215 HP V6 and 3) the AMG V6. The SLK32 AMG's engine has twin spark plugs per cylinder for maximum combustion. A newly engineered five-gear "SpeedShift" boasts 35% quicker automatic shifts. The SLK32 AMG uses lower (numeric) transmission gears and a 3.07:1 rear axle for an electronically limited top-speed of 155 mph. The standard four and six cyl. engines retain supercharging. Tell Aid services were expanded.
The AMG supecharger is the Lysholm-type (screw type) which provides boost virtually from idle speed. The AMG variant has reinforced suspension and newly designed wheels for better brake cooling. Brakes became 13.15" diameter vs. 11.8" standard. Revised air dams/spoilers minimize and balance aerodynamic lift front-to-rear and top speed. A small lip spoiler at the trailing edge of the trunk lid reduces rear airlift by more than 50%. AMG interiors introduce more bolstered seats, unique two-tone leather and dark birds-eye maple wood. AMG instruments are finished in silver. The warranty included free adjustments and regularly scheduled maintenance for the full four years or 50,000 miles.
2003: No major changes or new features.
2004: Beginning in July 2004 a Special Edition was available with highly polished, win spoke 17" wheels and high performance tires, newly designed sport seats and roll bars covered with Nappa leather.
2005: New Body R171 Replaced the R170.
Administrator (Canada)
If you go to the top and "search community" and enter 1996 , you will find a lot of posts in the R170 General Discussion forum. Many members had cars from the late '90s and I found one that had been here about 6 months ago (another 5 yr ago, etc).
You might consider sending them a message via conversation (click on their avatar -to the left under their username- and scroll down a bit to "start conversation" and ask them when they got their R170. If they still have the same email, they may very well be able to give you some assistance (y)
Just a thought 😉
1998 SLK230K
Discussion Starter · #14 ·
1. normal
The 1st sentence says it all...
"The SLK was announced to the USA market on Sept. 7, 1997 as a 1998 model; it was available in Europe during 1997."
Mine has a build date in 2/1997... a delivery date of 2/24/1997 and sale date in March of 1997.... I think Im still looking good
1 - 14 of 14 Posts
